Best place to get switched power under seat? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 04-21-2015, 12:12 AM Thread Starter
Hi, I am currently already using the aux plug on the right side of the bike and the heated grip connector on the left side of the bike so I prefer not to use these if possible.
I would like to get switched 12v power under the seat for a dash camera module. I am going to connect a 5v 1amp USB plug, so maybe 5-10watts total.... (I guess around half an amp at 12v)
Thanks.
bandroidx is offline
post #2 of 14 Old 04-21-2015, 12:30 AM
Im not the wiring guru, but I've read a lot of posts that people use the brake like for a switched relay. That doesnt give you the power you're wanting, but would help you created a switched circuit. A lot of guys like eastern beaver pc8 if youre gonna wire up more stuff in the future...might want to do that. There are smaller fuse blocks and cheaper ways to go. GW is like Wikipedia for stroms, so he'll probably respond and give you what you're looking for and make me look ignorant in the process, but hey, im used to it.
bsevans5 is offline
post #3 of 14 Old 04-21-2015, 12:41 AM
chicago's Avatar
Tail light wire is accessible under the seat. Tap it directly or use it to trigger a relay depending on your current needs.
14 tooth for me
chicago is offline
post #4 of 14 Old 04-21-2015, 04:48 AM Thread Starter
I am already taping the brake light for both my scorpio alarm and the backoff xp module. I am guessing that I will need to add a relay for my usb charger.
Perhaps I will use something like this: http://www.amazon.com/dp/B00L3OJW4C/...I3GJRH0DHQF3OZ
$85 is a little steep though for a relay......
post #5 of 14 Old 04-21-2015, 04:55 AM
Sgt Schultz's Avatar
I have that Fuzeblock in my bike also had one in previous bike. Well worth the money to set yourself up right. Keep tapping into different wires or the same wire many times will eventually lead to a problem.
Two leads to battery and one switched lead (hot) then you can run 6 accessories from it, some Fuze blocks have ability for 8 extras.
In my opinion it is worth the outlay.
I know nuffink, I see nuffink, It was not me, I was not here.
IBA #45920
FarRider #299
2015 Wee Strom "Piglet"
Givi crash bars, Barkbusters, Ravetech Bash plate, Ravetech Rad guard, Ravetech over dash Ram mount, Hyperlite flashing brake lights, Madstad bracket and screen, Augustus wind deflectors, Spot 3, UHF two way radio, Garmin Zumo GPS, Starcom intercom, Fuze block.
SW Motech Centre stand, Suzuki power outlet. Bike Alarm, Screaming Banshee horn, Led Flood lights, Tool tube, Andy Strapz Expedition soft panniers and frames.
Sgt Schultz is offline
post #6 of 14 Old 04-21-2015, 05:07 AM
I also have that Fuzeblock and I really like it. It's a clean solution for providing both switched and unswitched power for accessories. I thought it a bit pricey at first glance, but found it reasonable when I started pricing alternative solutions.
Bob
07 Wee
10 NT 700
BobAgain is offline
post #7 of 14 Old 04-21-2015, 08:09 AM
There is a connector at the rear left connecting a brown wire on the front side and a gray wire on the back side. That is tail light power and will come on when the ignition switch is on or in P(ark). An orange wire with a green stripe runs under the coolant reservoir in back of the tank. It carries power to the rear brake switch and is on whenever the ignition switch is on.
post #8 of 14 Old 04-21-2015, 09:18 AM
Randy_K's Avatar
Taping in all over is just asking for problems. Wiring is best done once and done neat. I use this fuse box to allow me to chose between having the item as switched power or constant power. If I have a problem it is much easier to trouble shoot.
2014 650 V-Strom , 2011 Husqvarna TE630, 1977 Canam 250 Qualifier, 1976 Yamaha TY175 Trials , 1978 Yamaha TY250 Trials , 1974 Suzuki RL250 Trials. < Past bikes... about 45 of them >
Randy_K is offline
post #9 of 14 Old 04-21-2015, 03:10 PM
Eastern Beaver also has a 3-Circuit Solution for a little less money than a fuse panel.
Look just below the PC-8 on this page ...
VStrom
Chris
2014 DL650 - Red
Former bikes ...
2005 DL650 - Red ... totaled Aug-2013
2007 Yamaha V-Star Silverado 650 - Black & Blue ... sold
1984 Honda Magna V45 (700 cc) - Black ... sold
2001 Honda Elite 50SR (hopped up to 72cc ... woo hoo!!!) - Red ... sold
TVdoorknob is offline
post #10 of 14 Old 04-21-2015, 04:47 PM
chicago's Avatar
VStrom
nice and it plugs right into your circuit. no muss no fuss. what I've done is wire everything off the battery. easy but it ain't pretty and I used longer battery bolts.
horn relay, headlight relay, sae pigtail and coax pigtail for vest/glove heat controller. for charging stuff I have a 12 volt socket that I plug into the sae pigtail and lay it in my tank bag.
14 tooth for me
chicago is offline
