Help with front fender nut - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 04-19-2015, 08:26 PM Thread Starter
I'm installing brake lines and having some issues with the fender bolts on the forks that hold brake line clips---there is apparently a square fender nut, that sits up inside the fender well, that is threaded and holds the allen head bolt. On one side i tried to remove it but the fender nut seems to just be spinning around up there. Guessing it may have been improperly installed and is not sitting properly. Anyone else run into these issues and have any suggestions??
Here is a picture of the nut, on the side where it came off fine and is now back on fine.
Sabreman is offline
post #2 of 12 Old 04-19-2015, 08:39 PM
dravnx's Avatar
there is no real trick to getting the bolt out. If the nut is spinning, you'll have to grab it with something. You might try shoving something up there that will wedge the nut in the recess. You might have to pull the front wheel to access the nut if that doesn't work. Many have epoxied the nut in place to prevent it from spinning in the future.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
smiles miles=bike.
It's simple math.
https://www.directavionics.com/
dravnx is offline
post #3 of 12 Old 04-19-2015, 08:55 PM
Spec's Avatar
See the sticky thread top of the page: Front Fender Warning
Spec is offline
post #4 of 12 Old 04-19-2015, 09:16 PM Thread Starter
Yes, that is exactly my problem. I missed that sticky before--wish I had seen the warning. Now I will try to grab it with some pliers or vicegrips, or else pull the wheel to epoxy the nut for good. The bolt was incredibly tight and doe have the red/orange heavy duty Locktite---which sure seems like overkill and cause the nut to break out of its slot and spin.
Sabreman is offline
post #5 of 12 Old 04-20-2015, 11:02 AM
Spec's Avatar
I had my front wheel off... I jammed a flathead screw driver up in there to stop the rotation.
I replaced the OEM nut plates with nylock nuts and washers.
Spec is offline
post #6 of 12 Old 04-20-2015, 11:51 AM Thread Starter
Thanks--gives me hope. no luck so far jamming it or gripping with pliers.
Sabreman is offline
post #7 of 12 Old 04-20-2015, 10:12 PM
That slot is so small, I wasn't able to grip it with anything, but did wedge a really fat, flat-blade screwdriver in there to hold it. But then, mine wasn't spinning freely at the time. Maybe try spraying some penetrating oil like PB Blaster up in there and let it soak before re-trying.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #8 of 12 Old 04-21-2015, 10:50 AM
Spec's Avatar
The red Loctite is heat de-activated. I didn't try this but you may be able to carefully heat the nut plate/screw to help loosen things up.
I forgot to mention that I ended up re-using the nut plate because the (larger diameter) shoulder fits into the hole of the fender. I filed out the threads and used a nylock nut behind it.
Spec is offline
post #9 of 12 Old 04-21-2015, 04:06 PM Thread Starter
I forgot to mention that I ended up re-using the nut plate because the (larger diameter) shoulder fits into the hole of the fender. I filed out the threads and used a nylock but behind it.
I did not know that--thanks. I will try my heat gun and hopefully won't melt all the plastic in the process. The PB Blaster spray does not seem to be doing the trick.
Sabreman is offline
post #10 of 12 Old 04-25-2015, 04:10 PM Thread Starter
Thanks for all the replies. Finally got the bolt and square well nut off---but very frustrating to get this done with the wheel on. Access quite limited and could not get heat up in the well to loosen the orange locktite, PB Blaster did not help, nor could I get a grip with needle nose or small vicegrips despite many tries. What ultimately worked for me was a small (6" total length) screwdriver with a thin 1/8 flat head, that I could wedge and lever under the square well nut to jam it in place. It can be done.
I'm drilling and filing off the threads inside the square nut, so that I can still use it as a washer, and trying to epoxy a 6M nylon lock nut on the backside of it to hold the bolt in place.
Sabreman is offline
