Speed sensor bolt removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
LinkBack Thread Tools
Old 04-13-2015, 09:46 PM Thread Starter
I'm in the process of replacing my worn sprockets and chain and need to remove the speed sensor rotor, it seems, to access the big nut on the sprocket. The sensor itself is now out of the way. So far, my attempts to remove the allen bolt in the center have failed and I've bent a decent wrench in the process. I'm assuming this is a normal right hand threaded bolt? Do I need to apply heat to break it loose? Am I doing something wrong?
I have a big road trip planned in a few weeks and am doing some prep work beforehand. FWIW, after lots of cleaning since last summer, I found more Dalton Hwy mud packed in there today. I'm not sure I'll ever get it all off the bike.
Thanks in advance!
Troy
Tee Bee is offline
Old 04-14-2015, 12:42 AM
SNB Tools's Avatar
Allen head cap screws are notorious for this. Hit it with a little penetrating fluid and then tap on it lightly with a small hammer several times and then try your Allen wrench again. Sometimes if you load the Allen and then tap on the end of it sharply it may break loose. A hand impact driver most always works.
To prevent this happening again (no guarantees) install the screw with a little anti seize on it.
SNB Tools is offline
Old 04-14-2015, 09:36 AM
D.T.'s Avatar
Try and loosen it after a ride or use a torch. Probably has the orange loctite of death on it if it's the first time removed.
D.T. is offline
Old 04-14-2015, 11:24 AM
Yeah first time removal is tight, a really good quality hex bit on a socket does wonders with a bit of heat applied to the bolt. I add some blue loctite when I torque back on, red is overkill!
Old 04-14-2015, 07:01 PM Thread Starter
Thanks guys! This forum is sure handy at times. I soaked it with WD40 while I went to work for the day and bought a new air ratchet on the way home. She broke loose fairly easily after that. Job is going well now.
Tee Bee is offline
Old 04-15-2015, 07:19 AM
D.T.'s Avatar
Use the money you save from bringing it to a stealer and buy your own tools.
D.T. is offline
Old 04-15-2015, 10:16 AM Thread Starter
That's my usual technique.
Tee Bee is offline
