Ended up being a Trivalve Sunday - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 04-12-2015, 08:57 PM Thread Starter
BSK
BSK's Avatar
Arrow Ended up being a Trivalve Sunday
So finally got around on checking in on the valves just short of 21K.
Bike is a daily highway commuter and does around 90miles a day.
all intakes were fine, 3 of the exhaust valves were tight. All three exhaust valves had 1.68 shims installed from the factory.
Fellow board member Joey borrowed my kit some weeks ago and did his valves. Not sure what his numbers were but I ran out of 1,6 shims and used 2x 1,6 and 1x 1,55 shims to get the job completed.
Paper shows 1,65 but should read 1,60
Rest of the entire album can be seen here:
Vstrom Valve BSK - Album on Imgur
Stephan
DL650AL02 -> Barkbuster handguards, 12V outlet, Lee Whitehurst luggage racks, JCWhitney Topcase, 3M reflective tape, P3 lights, 52w LED fogs, forkbrace, Puig 5895h windshield... more to come!
Failures:
Chain and sprockets worn at 9100 miles, recommended to be replaced despite every 500 mile adjustment and lube =(
Entire wiring harness replaced at 9233miles by SEP after headlight failure
Rear shock busted at 9727miles
Bad burned oil smell since 9500miles found to be disconnected drain tube from airfilter housing
2nd chain done at 21.6k
BSK is offline
post #2 of 8 Old 04-12-2015, 09:24 PM
Alter Falter,da hast du die Kiste ja komplett zerlegt
Danke für die photos, gute Arbeit !
vegeta2410 is offline
post #3 of 8 Old 04-12-2015, 09:27 PM Thread Starter
BSK
BSK's Avatar
Ja det ging ganz gut mit dem Cockpit ausm weg. 2 Bolzen und 3 Kabel und schwupps!
Hauh wech die Scheisse!
Stephan
Failures:
BSK is offline
post #4 of 8 Old 04-13-2015, 03:21 PM
Dat muss kesseln
post #5 of 8 Old 04-13-2015, 10:36 PM Thread Starter
BSK
BSK's Avatar
Ich dachte immer hier sind nur Ammis..
Stephan
Failures:
BSK is offline
post #6 of 8 Old 04-14-2015, 09:02 PM
Nope, gibt zu mindest einen niederrheiner. Ohne deutscher Fachkraft gehts hier hält auch nicht
post #7 of 8 Old 04-15-2015, 08:43 PM
Haha. My shims were all .172-.175 from thr factory. All four of my exhaust valves were too tight. One being at .012.. whoops!
fragile_this_side_up is offline
post #8 of 8 Old 04-16-2015, 12:42 PM
Vamos agora postar em outras linguas? Muito interessante esse post.
Ride safe!
V Strom DL650 - 2013 Riding
V Strom DL1000 - 2007 Sold
Honda Shadow 750 - 2000 Sold
Pauloxxi is offline
