Gear Indicator - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 04-08-2015, 08:05 PM Thread Starter
Gear Indicator
Just wondering what has been the most common fix for those of you who have suffered gear indicator problems. Thanks
jxbaha is offline
post #2 of 9 Old 04-09-2015, 03:06 AM
Hi Mate, What problems did you notice?
On my 2014 I noticed that sometimes it plays up between first and second gear although i would still be on first.
0Chili0 is offline
post #3 of 9 Old 04-09-2015, 05:19 AM
There's a plate down inside the left hand sprocket cover where the switches are for the gear indictor.
Pull the sprocket cover off, take a look at the wiring, 90% chance someone has pinched the loom and cut a wire. The other 10% is behind that plate. Pull it off, clean everything, put it back.
Pete
PeteW is offline
post #4 of 9 Old 04-09-2015, 10:21 AM
Longshadow's Avatar
Great Timing
I'm overdue for chain/sprocket replacement. I've been pushing for the last miles from this set before a 20Kmile summer that I'm hoping for. I'm at 39K on the odo now and I've begun to see the funky and random gear indicator drift that you mention and it is getting worse. But I'll clean it up or repair the wire or potted sensor.
Thanks, and perfect timing.
Ride well.
Ride well.
Longshadow is offline
post #5 of 9 Old 04-10-2015, 04:33 AM
Thanks Pete
0Chili0 is offline
post #6 of 9 Old 04-18-2015, 07:56 PM Thread Starter
Pete
Sorry, been away but wondering if this is a wet plate and what needs to be cleaned? Thanks
jxbaha is offline
post #7 of 9 Old 04-19-2015, 06:05 PM
Bigmuff's Avatar
I had the same issue. The indicator was randomly jumping around, and often displaying the wrong gear. I unbolted it and cleaned it with a rag, then put it back on. Worked fine for a week and then the problem came back. But before I could re-examine it, it started working normally again. I don't have an explanation. Perhaps whatever was gumming it up flushed itself out.
The sensor itself is pretty easy to get to, but check out this thread for some more detailed info and some photos. The SV650 has roughly the same engine.
code c31 - gear position sensor - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Edit: an even better link: https://www.stromtrooper.com/dl1000-2...problem-2.html
Bigmuff is offline
post #8 of 9 Old 04-21-2015, 09:23 AM Thread Starter
Much appreciated. Thanks
jxbaha is offline
post #9 of 9 Old 04-21-2015, 02:07 PM
I read thru the attached threads and understood the procedures. What I could not determine is, does the clutch cover gasket get replaced, or do we reuse the original gasket?
No one mentions it, so I'm assuming the original is reused. But, I figured it is worth asking, and mebbe I just keep a spare gasket handy, just in case?
2007 Suzuki DRZ400-S
2012 Suzuki DRZ400-S (sold)
2012 WeeStrom
2012 Kaw ZX-14R
2013 Yam WR450F (sold)
mebgardner is offline
