rattle at 5500RPM (2014 v strom 650) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 04-07-2015, 02:20 AM Thread Starter
Angry rattle at 5500RPM (2014 v strom 650)
I have visited many of these threads and have heeded to advice but have yet to find the source of the rattle, Pre- and post-farkle. I have narrowed it down to the left hand side near the front. Definately a high frquency metallic (washer?) rattle. Can anyone identify it from this video?
Bike has 2200 miles on it and it doesn't make a difference on the gear or the engine or ambient temperature.
please copy and past this link>youtu.be/nvvxQ9un_GU<
StromStad is offline
post #2 of 4 Old 04-08-2015, 07:24 PM
PcolaDennis's Avatar
Most likely the crash bars. You can try a piece of rubber between where the halves join in the front of the engine. A skid plate like the one I have also eliminates it, but it also reflects more engine mechanical noise upward.
Dennis
'12 650 Adventure
Madstad 22inch Adventure windscreen & bracket
Adventuretech fork brace & mirror extenders
Enduro Guardian skid plate and radiator guard
Grab-on grips
Suzuki top box
PcolaDennis is offline
post #3 of 4 Old 04-08-2015, 08:21 PM
TinMan2's Avatar
I had a front windscreen brace crack on a different bike and it would "sing" identical to your sound at a certain rpm. It took me almost a year to find it when I was going thru the brace looked fine. It was cracked all the way through but when it wasn't being vibrated it just fit together. I had to actually pull on everything until I found the break. It drove me nuts.
If you have a friend that can hold the throttle at 5500 you could use a paper towel tube and isolate it to the exact area. then poke and pull on everything until you find what's loose. It's metal to metal. Good luck............Mike
TinMan2 is offline
post #4 of 4 Old 04-08-2015, 08:34 PM
Stromtrooper.com Sponsor
Satch's Avatar
Sorry I can't help on the rattling noise, but here's how to insert your video into a post. Cut the numbers (shown in blue) from the youtube link and paste it into the following format:
[youtub]nvvxQ9un_GU[/youtub] (But spell it youtube)
Hopefully this will make it easier for others to view it and give you some suggestions as to the cause of the rattle.
:arrow: Follow the V-Strom Cache Adventure | See Where the Cache has Been | Play the Stromtrooper Picture Game | Play the Weekly Picture Game
Preferred V-Strom Model Nicknames: 02-12 DL1000 Vee, 2014+ DL1000 ABS Vee2, 04-11 DL650 Wee, 12-16 DL650 Wee2, 17+ DL650 Wee3
V-Stroms I've owned: Wee.07, Wee.11, Wee2.13. Currently Wee-less
Satch is offline
Tags
2014 , 5500 , rattle , rpm
