Just installed a Tutoro Auto Chain Oiler - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 47Likes
post #1 of 106 Old 04-06-2015, 10:36 PM Thread Starter
Ned
Just installed a Tutoro Auto Chain Oiler. This design is finally available in the US from Adventuretech (I am not affiliated with them). The Oiler design is all mechanical and works from the bike's motion, no electric or vacuum source is needed. Just mount it and it's ready to go.
I did make my own reservoir mounting plate and a mounting bracket for the twin-feed nozzle. It dribbles a little oil on the chain as you ride and appears to work very well.
Here is where I purchased the oiler. He does sell a Deluxe and Standard version
http://www.adventuretech.biz/tutoro-...e-edition.html
EMFL and Old Time Rider like this.
Last edited by Ned; 04-25-2015 at 10:38 PM. Reason: Added link to Adventuretech Oiler
Ned is offline
post #2 of 106 Old 04-09-2015, 02:52 PM
Kelly2012's Avatar
Thanks for the pics, Ned. Are you taking orders for the brackets?
VSrider likes this.
Kelly2012 is offline
post #3 of 106 Old 04-09-2015, 03:10 PM
kiwi_outdoors's Avatar
Zip ties
MAke sure that your Zip ties are UV stable. I put some on my TV antenna mast and they fell apart after a few years.
DesertBike likes this.
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #4 of 106 Old 04-09-2015, 06:03 PM Thread Starter
Ned
No I am not into manufacturing but you could ask Rick at Adventuretech if he would be interested in making them. He is selling the Tutoro chain oilers. I would be willing to provide the templates (PM me if interested). I made my brackets from some aluminum plate I had laying around. Tutoro does make a nozzle mount but it is not V-Strom specific. Here is their mount:
Anchor Kit - AdventureTech, LLC.
Thanks for comment on the zip-ties. This is what Tutoro uses to mount their system. These are black and that would provide some UV protection but I will keep an eye on them. I could upgrade to a stainless steel hose clamp.
Ned is offline
post #5 of 106 Old 04-10-2015, 07:18 AM
strominateacup's Avatar
I fitted one of these to mine a couple of months ago, it works really well using chain saw bar oil, I'm very happy with it.
There are holes in the sky where the rain gets in,
and the holes are very small, that's why rain is thin.
Spike Milligan.
strominateacup is offline
post #6 of 106 Old 04-10-2015, 10:23 AM
Borghi's Avatar
Never saw these before. Have been using a Scottoiler for years. Wouldn't be without one.
Borghi is offline
post #7 of 106 Old 04-12-2015, 03:11 PM
RadRider's Avatar
Liking the simplicity of this design - the Scottoiler looks great, but not cheap and for the electronic version having an LCD display for an oiler just seems like overkill. Looking like another addition to the farkle wishlist... Wonder why these seem to be all developed in UK? Brits have special chain oiling skills?
RadRider is offline
post #8 of 106 Old 04-12-2015, 04:18 PM
Yes, they do, they've got a proud tradition of making bikes that leak oil. Some of it is bound to end up on the chain.
Brockie, eagleeye, jim_me and 8 others like this.
Spike Milligan.
post #9 of 106 Old 04-13-2015, 09:59 PM
Bud
Bud's Avatar
That's funny and you didn't even mention Lucas.
Ride Well and you will Ride Safe.
Bud is offline
post #10 of 106 Old 04-13-2015, 10:33 PM
BSK
BSK's Avatar
the british always ride in the rain so you better lube everything
Stephan
DL650AL02 -> Barkbuster handguards, 12V outlet, Lee Whitehurst luggage racks, JCWhitney Topcase, 3M reflective tape, P3 lights, 52w LED fogs, forkbrace, Puig 5895h windshield... more to come!
Failures:
Chain and sprockets worn at 9100 miles, recommended to be replaced despite every 500 mile adjustment and lube =(
Entire wiring harness replaced at 9233miles by SEP after headlight failure
Rear shock busted at 9727miles
Bad burned oil smell since 9500miles found to be disconnected drain tube from airfilter housing
2nd chain done at 21.6k
BSK is offline
