Creaky Front brake lever - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By 568v8
post #1 of 8 Old 04-06-2015, 02:55 AM Thread Starter
Theoldsod's Avatar
Just to start, I know its NOT the lever thats 'creaky'....BUT!!
When I pull the lever in it feels creaky, staggers, NOT smooth?
If i give it 3 or 4 good long squeezes it feels 'normal' but after 30mins or so it goes back to creaky.
I am at 88000km so im looking to change the fluid/bleed brakes etc.. just wondered if anyone else had this, what was it, what did you do to correct it?
Cheers...
Just because you're breathing doesnt mean you're alive
Gs500f 200,184kms RIP
Dec 2012 DL650 158000 kms
Theoldsod is offline
post #2 of 8 Old 04-06-2015, 10:34 AM
You may want to change the fluid, flush the system.
Lubing the pivot point won't hurt either.
post #3 of 8 Old 04-06-2015, 12:17 PM
You have a cable operated clutch. Grease the pivot and the barrel end on the cable. Do not lubricate the cable itself. Check the sprocket cover area for chain lube build up.
post #4 of 8 Old 04-09-2015, 03:04 PM
Kelly2012's Avatar
The only way I could resolve what you describe in the past has been to rebuild the master cylinder- the hardest part of the job is finding your circlip pliers.
Suzuki ALL Balls Front Master Cylinder Rebuild Repair KIT DL1000 DL650 A V Storm | eBay
Kelly2012 is offline
post #5 of 8 Old 04-09-2015, 03:55 PM
I've had this problem on some older Honda motorcycles I've had - I got rid of the problem by flushing the brake fluid and rebuilding the brake master cylinder. That kit above should work. Sometimes the rubber seal & boot can let dirt in, I guess.
Fillycheezstake is offline
post #6 of 8 Old 04-10-2015, 10:48 AM
568v8's Avatar
creaky levers
I had the same "creaky" problem on my Vee with both clutch and brake levers. Simply solved by cleaning and greasing the pivot pins.
Mulewright likes this.
Road Toads Charter Member - old guy goes stromabout on a 2007 Vee and finally has touched all of the 48 contiguous United states and the 10 Canadian provinces.
568v8 is offline
post #7 of 8 Old 04-15-2015, 07:47 PM Thread Starter
Theoldsod's Avatar
Sorry guys for slow response....been away from the pc for a while.... I have cleaned greased, flushed and replaced fluid...still a 'little creaky? I'll persever for a while and see what transpires, but maybe i will have to rebuild the Master cycinder.
I'll post what ever happens. Thx for all advise!
post #8 of 8 Old 06-06-2016, 09:05 AM
kiwi_outdoors's Avatar
sticky lever here
once in a while it seemed like my brake lever then released. So I took it apart for a cleaning. The mating surfaces were very gungy with old grease (?) and the pivot pin surface was rough. Pivot pin is noow all smooth.
I will report back after a month of riding.
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
