Rear wheel again - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 04-05-2015, 07:15 AM Thread Starter
dcv
Rear wheel again
Hi guys
The season is coming so I decided to change the rear tire / anakee 2 was my choice/. While taking it off was fairly easy putting it back seems like a challenge I'm in the process of doing it / 2 days now! / and it seems to me that it's not a one man job . Anyways what's preventing me from mounting this god damn tyre is the rear wheel speed sensor - it's sticking out so much that it is always in the way every time I try.. And I'm getting weaker and weaker.. So my question is - do I really have to remove it to be able to finish this job? I checked the manual - it clearly says : remove the sensor before taking off the wheel and be careful not to damage the rotator. Well I wish I'd referred to the manual in the first place instead of looking it up in the treads on this exellent forum
Seems like the newest model / mine 2012/ is somewhat different to the previous one at least as far as the calliper mount is concerned..Any help appreciated
dcv is offline
post #2 of 9 Old 04-05-2015, 07:59 AM
fortp's Avatar
You answered to your own question: Remove that speed sensor.
What could help very much is to make a wedge from a piece of wood, so that your wheel raise as you roll it on the wedge.
fortp is offline
post #3 of 9 Old 04-06-2015, 04:04 AM Thread Starter
dcv
yes wood, this I have plenty
fortp, have you ever done it before?
what puzzles me is that when I pulled out the axle it all fell apart so there must be a way..
removing the sensor is all very fine but putting it back is a problem - there is only about a milimiter tolerance between the sensor and the rotator so it takes a thickness gauge and a torque wrench .. I have a big t. wrench so I'll need to get a smaller one as well..
and the whole thing was meant to save some money
dcv is offline
post #4 of 9 Old 04-06-2015, 04:17 AM
The speed sensor just drops back in. Stop overthinking and just remove the damned thing before you break it.
Pete
PeteW is online now
post #5 of 9 Old 04-06-2015, 08:31 AM
Bikehigh's Avatar
Thickness gauge for what? There is zero to adjust. Torque wrench for what? There's one bolt. Snug it up and you're done. Takes like five seconds. Not a problem.
Bikehigh is offline
post #6 of 9 Old 04-07-2015, 03:58 AM Thread Starter
dcv
all right , I'll follow your advice
it's just that in other posts in many threads on the subject nobody mentions removing the sensor / at least I didn't see anything/ so I was kind of misled..
I'm a little nervous about this thing as the sensor is a solid piece of metal and I like riding fast ocassionally so if there is only about a millimeter clearance you can imagine what could happen if the thing got stuck in there while going, say 190km/h ...
och, btw, they do measure the clearance with a gauge in the service manual
dcv is offline
post #7 of 9 Old 04-07-2015, 04:47 AM
Pretty low risk. It's a solid fit, no shims and mine must have been out 10 or so times so far.
The only way that spacing would change would be a missing or wrong spacer somewhere.
Pete
PeteW is online now
post #8 of 9 Old 04-07-2015, 10:08 AM
Leaving it in while changing the tire is way more likely to damage it or affect the clearance than taking it out. I don't see how the clearance could change with it out.
post #9 of 9 Old 04-08-2015, 03:26 AM Thread Starter
dcv
now things are a lot easier!
one can always count on you guys
thank you..
dcv is offline
