Chain slack adjustment question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 04-04-2015, 02:09 PM Thread Starter
This is a pretty basic question, but I can't find much using search. What is the official exact procedure meant by "measure the slack". The Haynes manual simply says push up and measure the slack, doesn't say whether that's pushing down or not, or how much pressure. (I don't have the factory service manual.) When adjusting my chain, I've always measured it from pushing down, to pushing up (using moderate pressure) and put it on the loose side of the specs (1.25-1.5" for the 650). In other words, push down and measure to bottom of link, push up and measure to bottom of same link. So I got to wondering if Suzuki intended that the lower measurement should just be with the chain at rest with no downward pressure? That might account for the 20 - 30 mm "tight" adjustment the manual recommends.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #2 of 3 Old 04-04-2015, 02:47 PM
Your method is fine. I think the manual method is too likely to get a worn chain set too tight.
post #3 of 3 Old 04-04-2015, 02:58 PM
Laser
I had a handlebar wobble when I took my hands off the bars. I bought a laser chain alignment tool and the wobble stopped. Might be coincidence or tire wear.
Just thought I'd pass it on.
Best
Rockies Rider is offline
