Rostra installed but have a problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 03-21-2015, 09:05 PM Thread Starter
Ned
I just installed a Rostra CC on my 2013 Glee. Went for a test ride and everything worked great except when I pulled the clutch the engine would rev up past 8000 and then I hit the kill switch. Tried this multiple times and the CC would not shut off when the engine rpm climbed. Does anyone have an idea what might be wrong? I did not install any relays. I am pulling the bike back apart to look for the problem.
I copied the wiring diagram noted by others on this site and have the:
- Grey (VSS) wire connected to the pink with white strip
- Blue (tach) wire connected to the brown with black strip
see attached picture
Here are my dip switch settings:
1 Off
2 Off
3 Off
4 On
5 Off
6 On
7 On
8 Off
9 Off
10 On
11 Off
12 Off
SOLUTION?? I found this idea on the site and I am tempted to try it. Connect the Green wire from the main control unit (Neutral Safety Switch) to the clutch switch if you want the cruise to cancel without over-revving when you pull the clutch, and change dip switch 11 to "Automatic".
Ned is offline
post #2 of 15 Old 03-21-2015, 10:51 PM
Here is the wiring diagram without relays. I never got it to work with them but with the relays taken out it works fine. I'm pretty sure mine is wired like this except the 10A and 4A fuses are in my fuse block. It requires an incandescent bulb in the tail/stop light. I use the same dip switch settings. The difference in rpm when grabbing the clutch has canceled the CC just fine on two bikes I've had CC on. I don't use the engage light so orange and pink aren't used.
Rostra wiring diagram without relays by Greywolf, V-Strom rider, on Flickr
See Rostra CC Wiring Diagram for more info.
post #3 of 15 Old 03-21-2015, 11:19 PM Thread Starter
Ned
This is the same wiring diagram I used. I have the stock tail light and did not install any relays. Everything else works fine - set, off with brake, resume, accel, decel .
Could I have a bad CC unit?
Any reason not to try the CC Neutral wire?
Ned is offline
post #4 of 15 Old 03-21-2015, 11:35 PM
I haven't read anything about using the green wire. All I've seen is using a relay controlled by the B/Y clutch switch wire to interrupt the purple wire connection.
post #5 of 15 Old 03-22-2015, 01:36 AM
Ned - See page 21 of the Rostra Installation & Owner's Manual. It says you can use the diagnostic mode to test your tach signal. In this mode the diagnostic LED should blink faster at higher revs. I did not run the tach signal test on my install but it sounds pretty simple. If your tach signal turns out to be invalid, you might consider using a Posi-tap to connect your dark blue wire to the bike's brown/black tach signal wire.
Posi-Tap- No Crimp Tap
Greywolf - I think that wiring diagram may have a junction shown incorrectly. Looks like the 12V+ going through the 4 amp fuse hits a junction and returns directly to 12V-. I think the red wire from the switch has a little segment shown that mistakenly connects it to 12V-.
Chris
2014 DL650 - Red
Former bikes ...
2005 DL650 - Red ... totaled Aug-2013
2007 Yamaha V-Star Silverado 650 - Black & Blue ... sold
1984 Honda Magna V45 (700 cc) - Black ... sold
2001 Honda Elite 50SR (hopped up to 72cc ... woo hoo!!!) - Red ... sold
TVdoorknob is offline
post #6 of 15 Old 03-22-2015, 01:57 AM
I took out that little stub of red wire and some other unused wiring.
post #7 of 15 Old 03-22-2015, 10:17 PM Thread Starter
Ned
I went into the Rostra diagnostic mode to check the tach wire and the connection is OK. As the revs climbed the light flashed faster. I installed my CC inside the fairing so it is a complete teardown to be able to see inside the unit. Since I had a problem I hate to just put it back together and may go ahead and install a clutch relay. Unless there are other ideas.
I know someone else on this site tried connecting the Neutral wire from the CC to the clutch wire on the bike. I will do more research.
Thanks for your help.
Ned is offline
post #8 of 15 Old 03-26-2015, 12:11 AM
Ned - I had the cruise set a couple of times today and pulled the clutch to see how much it revved before cutting off the cruise. Once I was going about 60 mph indicated and another time about 50 mph indicated. Both times the bike revved about +2000 rpm before cutting off the cruise. With the clutch pulled it revs up pretty fast so it only takes an instant to rev and cut off. I can certainly see if you are at freeway speeds it could rev past 8000. Have you set your CC a lower speed (maybe 45 mph) and pulled the clutch to see if it cuts off before getting too high for comfort?
I use my CC a lot and don't think I've ever had to rely on the over-rev to shut it down. Whether I'm on the freeway or back roads it's always just a quick touch of the brake to disengage the cruise. The only few times I've used the over-rev was when playing around with it to see how well that worked.
Chris
2014 DL650 - Red
Former bikes ...
post #9 of 15 Old 03-26-2015, 07:38 AM
Mine revs up fairly high when I pulled in the clutch to test it also. But it did release. I don't figure I will be pulling the clutch lever in normally while c/c is engaged so I am good with how mine works.
Mine might go to 8k or higher. But even that is not an issue. Wouldn't care to see it bouncing off the rev limiter, but if cruising at 5500-6000 and it bumps to 8000 I don't feel that is excessive.
realshelby is offline
post #10 of 15 Old 03-26-2015, 07:51 PM Thread Starter
Ned
Thanks for helpful comments. When I pull in the clutch and the revs climb I was ready to hit the Kill switch and never let the engine get to the rev limiter. I agree with your comments on not expecting to pull in the clutch with the CC on, and I may just leave it alone and ride it.
But from additional research it appears I can connect the Neutral Safety Wire from the CC (light green) to the "hot" (black with yellow tracer) wire going to the clutch lever switch and when the lever is pulled it will shut off the CC.
Strom Chaser shows this connection on his wiring Diagram. I will leave the Transmission dip switch at Manual.
https://www.stromtrooper.com/v-strom-...te-wiring.html
I also found others who had used the clutch wire connected to the NSS wire of their CC.
Ned is offline
