Signal Dynamics Modulator with Eastern Beaver H4 Relay- compatible? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 03-02-2015, 12:54 AM Thread Starter
Greetings- I've been searching and searching for an answer to a seemingly simple question- would appreciate any help.
I just ordered the well regarded Eastern Beaver H4 headlight relay kit with one light cut-off. I've also got a Signal Dynamics dual H4 headlight modulator on the way.
Can these both be hooked up together?
On the Eastern Beaver site it says to plug the modulator directly into the bulbs and the relay kit into the modulator (that's on bulbs)- problem is that if you look at the modulator sockets, it doesn't look like you can then plug the modulator into them (my info comes from a photo of the modulator on the Sig. Dyn. site).
If anybody has done this install with the two components- I'd be relieved to know it can be done.
Thanks.
bajarambler is offline
post #2 of 3 Old 03-02-2015, 02:21 PM
I have both installed and they work just fine.
FredBGG is offline
post #3 of 3 Old 03-02-2015, 05:57 PM Thread Starter
Thanks FredBGG- relieved to know I can plug the relay harness into the back of the modulator plugs.
Any tips for me regarding that install?
