Auxiliary USB Went Pop...then Smoked - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 03-01-2015, 11:35 AM Thread Starter
ColoradoSagebrush's Avatar
Looking for some help.
Yesterday I installed the plug and play items (PC8 and H4 Relay). All seemed to go great. Headlights work. Charging with my battery tender's pigtail attached to non-switched PC8 circuit.
However, this morning I installed my auxiliary shelf and connected the USB socket. Here's where I think I went wrong. I checked for positive/negative terminals on the socket, but then I think my A.D.D. kicked in an I may have reversed the black and red wires on the socket itself (this I can't prove b/c in my panic after the pop and smoke I disconnected the socket).
As soon as I turned on the ignition, the socket popped and smoked Can anyone provide some likely causes?
ColoradoSagebrush is offline
post #2 of 6 Old 03-01-2015, 12:03 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
If you got it from us shoot me an email, PM, or call. We will get you fixed up.
Rick
richlandrick is offline
post #3 of 6 Old 03-02-2015, 02:59 PM Thread Starter
Request for Advice
I think my A.D.D. kicked in an I may have reversed the black and red wires on the socket itself...
As soon as I turned on the ignition, the USB socket popped and smoked Can anyone provide some likely causes?
Can someone with electrical experience give me a little nudge. Is it likely/probably that I swapped negative/positive to cause my USB socket "release the magic smoke" and go poof? The circuit (with new fuse installed) measure 12+ volts on my voltmeter, and all other circuits on my fuse panel are functioning normally.
If it's something more complicated than that, I'm sure I am on my own and I realize it's an impossible question to answer.
Also, Rick at Adventuretech is AWESOME to work with. I'll buy everything from him going forward!!!!!!!!
post #4 of 6 Old 03-02-2015, 03:08 PM
dravnx's Avatar
Yeah, Rick is awesome to work with.
Reverse the polarity on a circuit=bad.
What more do you need to know?
Not much going on there to analyze. 2 wires, even color coded.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
smiles miles=bike.
It's simple math.
https://www.directavionics.com/
dravnx is offline
post #5 of 6 Old 03-02-2015, 03:59 PM Thread Starter
Nudge
Thank dravnx. That's exactly the "no duh" nudge I was looking for. I have no confidence when it comes to electrical.
post #6 of 6 Old 03-04-2015, 04:28 PM
Texan's Avatar
YES!
I did the same thing last week when I installed the PC8. I reversed the pos/neg on my USB power outlet. It made some clicking sounds the poof! Dead. And before anyone gives me the red vs. black lecture, I know, but both leads were black in this case. Once I clipped off the inline fuse, both leads were identical.
2016 BMW R1200RS
2016 Suzuki GSX-S1000F
2013 Suzuki DL650.. SOLD!
2017 Suzuki DL650 as soon as they hit the sales floor.
Texan is offline
