Vacuum location for Scottoiler - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 02-28-2015, 11:40 AM Thread Starter
Borghi's Avatar
I tried to find something on the forum but didn't see anything. I am installing a Scottoiler on my 2014 Glee and need some advice on where to hook in the vacuum line. The Scottoiler website states to tap into a vacuum line going to a MAP sensor, but I do not see where this sensor is or where the vacuum line is.
Any experience with this on the Glee?
Borghi is offline
post #2 of 14 Old 02-28-2015, 11:49 AM
Snownut's Avatar
Put in your bike info and you can download the specific installation guide for your bike.. Don't let the pre 12' wee picture throw you off..
http://www.scottoiler.com/uk/installation-guides.html
2014 Suzuki V-Strom DL1000 (Desi)
2014 Suzuki V-Strom DL1000 (Delilah) Rental
2013 Suzuki V-Strom DL650 (Misty)
2010 Royal Enfield Bullet 500 Army (Greta)
2007 Suzuki GS500E (Gina)
1987 Yamaha TW200 (Tina)
Snownut is offline
post #3 of 14 Old 02-28-2015, 12:01 PM
srpkcop's Avatar
I have a '12 650. You will find a vacuum under the gas tank on the throttle side of the bike. I cut it and put in the T that is supplied and works like a charm. I had zip tied the reservoir to the frame but found it got grimy with time and decided to relocate under the seat. It stays clean and easier to reach for refill.
2012 650 Expedition-well farkled
srpkcop is offline
post #4 of 14 Old 02-28-2015, 12:12 PM
2mstone's Avatar
Snownut knows whereof he speaks, he bailed me out when I was installing mine.
"Tombstone"
S-10
My Alaskan Adventure
http://2mbstonestravels.blogspot.com/2015/04/alaska-or-bust.html
2mstone is offline
post #5 of 14 Old 02-28-2015, 12:39 PM
"easier to reach for refill."
Cool that the unit only works with the engine is running. Supposing the unit is dripping at a reasonable rate, how many hundred miles do one get before the refill?
I can spray the chain at the end of a day but I may have gone 500 to a 1000 miles in that day when traveling.
post #6 of 14 Old 02-28-2015, 01:36 PM Thread Starter
Borghi's Avatar
Do I need to remove the gas tank to get to the vacuum line??
Borghi is offline
post #7 of 14 Old 02-28-2015, 01:39 PM Thread Starter
Borghi's Avatar
I have gotten up to 600 miles on one filling of the stock Scottoiler. I usually carry a small bottle of oil if I think I will be on the road for longer. Just sold my 06 Wee with 22,000 miles and the chain and sprockets still looked great. I think I only adjusted the chain twice while I owned the bike. Ever since I got the Scottoiler, I forgot about the downsides of chain drive.
Borghi is offline
post #8 of 14 Old 02-28-2015, 04:18 PM
Just lifted it up onto the support gave enough room when I installed and removed mine IIRC.
Oop North John is offline
post #9 of 14 Old 02-28-2015, 06:13 PM
2mstone's Avatar
I was able to reach the vac tube without removing or raising anything...not counting raising my voice with swear words...
The question was asked about range before refilling the oiler, I got the tour model and can go about 10,000 miles before filling the reservoir.
I typically got 30,000 miles per chain except on one that got about half that, I attribute that to a combination of bad installation (self induced) and dirt roads in Mexico.
One of the few negative things about the auto oiler is that I forget to check the chain for adjustment, and cleaning because it is so maintenance free.
"Tombstone"
S-10
2mstone is offline
post #10 of 14 Old 02-28-2015, 10:48 PM
randyo's Avatar
I used to get about 5000 miles before refill with the High Capacity Reservoir, but vibration caused it to leak and got messy and I have since installed a Lube Tube and get about 4000 miles
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
