Barkbusters Storm Handguard Kit - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 25 Old 02-23-2015, 03:49 PM Thread Starter
JoshM's Avatar
Alright, so I bought this kit from Revzilla and it looks like it'll finally show up today because UPS drivers evidently can't drive in snow... ugh. And they wouldn't even let me come pick up my package last Wednesday when it was supposed to be delivered. Sorry for my rant.
Is it as simple as the instructions look? Take off bar ends, put these on and ride? Instructions make it look like a 15 min install. But I just can't believe it's as easy as it looks.
I've been looking at a thread on here about them, but it's mainly arguing back and forth on which kit is better or worse. I can't really find anything regarding the install, which leads me to believe it actually is as easy as it looks.
JoshM is offline
post #2 of 25 Old 02-23-2015, 06:06 PM
vinnyvavoom's Avatar
my buddy has these on his cb500x, it is as easy as it looks to install them. Now it depends how OCD you are from there. Lining them up correctly/evenly can be quite interesting. You could spend days doing it.
_______________________________________________________________________________
There are 10 types of people, those who know binary and those who don't.
What I ride now:
2013 Honda GoldWing (The Lady)
2014 V-strom 650 (The Mistress)
Previously: 07 Ultra Classic, 95 Softail, 80 gs450l
vinnyvavoom is offline
post #3 of 25 Old 02-23-2015, 06:11 PM
emc2's Avatar
I also ordered them from Revzilla.
The install was about 20 minutes.
About the only mistake you can make is backing off the stock bar end screws too far.
emc2 is offline
post #4 of 25 Old 02-23-2015, 06:22 PM
mowcowbell's Avatar
Definitely pay particular attention to the comment above about "backing off the stock bar end screws too far". From the posts I've seen here, that's about the only mistake you can make during this install.
mowcowbell is offline
post #5 of 25 Old 02-23-2015, 09:41 PM
Yep, just want to loosen those screws and then wiggle and pull them out. Also, there has been some discussion about whether the inside aluminum bracket goes over or under. According to the diagram, they go under, which works great on the left bar, but on the right that puts it right up against the metal ferrule on the brake line. Someone pointed out that if it got whacked hard enough (like a drop) it might damage that line. If you reverse the bracket, it works good on the brake side, but the clutch cable rubs on it. I changed mine to this configuration and just wrapped some electrical tape around the clutch cable. The only other issue was that some of the bolts couldn't be tightened in the recommended order, but that wasn't really a problem. Since this might not make much sense, will try to find some pics to post.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #6 of 25 Old 02-23-2015, 09:49 PM
Under and over...
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
G-Dub is offline
post #7 of 25 Old 02-24-2015, 12:15 AM
2mstone's Avatar
Mine are; over on the clutch side, and under on the brake side.
On the clutch side I have my oxford heater controller attached to the bb bracket.
And yes,,,,you can spend a lot of time looking, re-adjusting, looking....etc.
"Tombstone"
S-10
My Alaskan Adventure
http://2mbstonestravels.blogspot.com/2015/04/alaska-or-bust.html
2mstone is offline
post #8 of 25 Old 02-24-2015, 10:10 AM Thread Starter
JoshM's Avatar
Thank you all! I suppose I'll tackle the install this weekend, unless I get some free time one afternoon this week.
... and thanks for the reminder regarding only loosening the screw!
JoshM is offline
post #9 of 25 Old 02-24-2015, 01:07 PM
2mstone's Avatar
Loosen a little and tap the screw... if is doesn't pull out loosen a little more, tap...etc.
"Tombstone"
S-10
2mstone is offline
post #10 of 25 Old 02-24-2015, 01:50 PM Thread Starter
JoshM's Avatar
Should unscrewing 1/4" suffice? Or is that too much?
JoshM is offline
