Suzuki Diagnostic System Tool Alternatives - SDS tool - DL650 2012+ - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 02-18-2015, 08:56 AM Thread Starter
Hey All,
I'm looking to perform a TBS on my 2012 DL650. I've seen some threads on this for the 2011 and earlier models but I wanted to find out if there's any update for the new engine. I'm not looking for a work around, I'm actually planning on buying the tool but I'd prefer to save money if I can...
It seems you can get a proper SDS tool for around 230$
I've also found another questionable tool for around 164$
And an even more questionable tool for less than 100$
Does anybody have experience with any of these tools?
farmersride is offline
post #2 of 8 Old 02-18-2015, 09:07 AM
The TBS procedure on the 650 is unchanged since 2007. The Suzuki SDS tool is only supposed to be sold to dealers and licensed bike shops. I use the HealTech OBD tool. The TBS procedure only affects the idle air screws so it isn't very important on a 2007 and up 650 unless the engine runs rough at 3000rpm. I had it done on my 2007 and it was one inch of Hg off. The only difference I felt was the engine ran well down to 2500rpm instead of the 2900rpm it needed before. I don't run under 3000rpm so it didn't make much difference. There is a procedure that gets the TBS close enough to be valid that doesn't need an electronic aid. Throttle Body Sync for DL650(A)K7, A How To
post #3 of 8 Old 02-18-2015, 10:10 AM Thread Starter
This is all true even for the 2012+ models (with gladius engine)?
post #4 of 8 Old 02-18-2015, 10:31 AM
D.T.'s Avatar
I remember when the SDS tool was $695.00 and the software was another $140.00! hmy:
I'm going to avoid buying it at all costs.
D.T. is offline
post #5 of 8 Old 02-18-2015, 11:04 AM
Yes. The affected systems are the same.
post #6 of 8 Old 02-18-2015, 11:55 AM
Luma's Avatar
Hey All,
Did you have a chance to check if your TBs/cylinders are actually that far apart to justify the synchronization? I do not even know what is the spec on this... Anyone?
2016 Honda Africa Twin
Luma is offline
post #7 of 8 Old 02-18-2015, 01:59 PM
For what it's worth... I bought a Chinese version of the Mercedes Star Diagnostic system,
(by the way that is a big fancy name for some very basic software).
The Chinese hardware and software work perfectly and cost me $ 80. That is about 1 1/10 of what stealerships charge here in Cali just to plug the star system in and readout the codes etc etc.
FredBGG is offline
post #8 of 8 Old 06-22-2015, 01:01 PM
Where
Can you please elaborate what is "Mercedes Star Diagnostic system"?
If works just like the Suzuki where did you get this?
Did it come complete all hardware, cables, software?
[FONT="System"][SIZE="4"] 07 WeeStrom NE Florida [/SIZE][/FONT]
2wrdr is offline
