How to access windscreen nuts? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 21 Old 02-12-2015, 10:34 AM Thread Starter
I just got (two weeks ago) a new 2013 WeeGlee. I'm getting the usual buffeting with the stock screen and thought I'd move it up to the top position to see if that helps. I'm stuck on how to get to the top holes in the fairing. I just can't seem to reach up into it to move the nuts into the top holes, and it's not clear to me how to remove parts of the fairing to gain better access.
Short of buying the shop manual (even though I'll have to do it sometime), can someone tell me how to get up in there?
scritch is offline
post #2 of 21 Old 02-12-2015, 10:44 AM
It's all done from the front. Take the screws out. Pull out the #23 well nuts from the center holes. Remove the #11 hole covers from the top holes. Insert the well nuts in the top holes and put the covers in the center holes.
post #3 of 21 Old 02-12-2015, 11:16 AM
Toytech's Avatar
I would like to add to that... With the windscreen off gently thread the screws back into the well nuts to provide a hand hold to wiggle them out. After moving all the plugs to the desired locations partly thread the screws and well nuts to the screen. THEN wiggle the whole assembly and well nuts into position. Well nuts can get pushed into the inside of the fairing and disappear if not attached to something. I speak from experience.
I don't mind the going and I don't mind the stopping. I absolutely hate the stop and going.
Toytech is offline
post #4 of 21 Old 02-12-2015, 12:13 PM
Originally Posted by scritch View Post
I just got (two weeks ago) a new 2013 WeeGlee. I'm getting the usual buffeting with the stock screen and thought I'd move it up to the top position to see if that helps...
It seems that moving the screen up should help but for me it works best in the lowest position. I tried the highest setting when I got the bike and didn't like it. Moved it back down - to lowest position as I recall.
2012 Wee2 Adventure. Black. Bought at 26K miles. Now 46K+. Love it!
HokiesRWee is offline
post #5 of 21 Old 02-12-2015, 12:32 PM Thread Starter
It appears that it isn't quite that easy. The nuts that hold the windscreen on have rubber bodies, with thick mid-body swellings that bear on the inside of the fairing. They have thin collars on the tops to keep them from falling out when you remove the screws. They can only be removed (and replaced) from inside the fairing.
Oh, well. I guess I'll just have to ask at the dealership.
scritch is offline
post #6 of 21 Old 02-12-2015, 12:52 PM
Absolutely not. I change my windscreens every year when the temperature changes. The well nuts come off from the front. Do not try to take them off using the screws as that makes the rubber swell more. Grip the tee tops and work them out. It's harder if the screws were overtightened. They should just be tightened enough to make the rubber swell, but they will still come out. The rubber swellings are above the metal insert so they will compress and allow removal.
post #7 of 21 Old 02-12-2015, 03:17 PM
Spec's Avatar
Try this to remove the well nuts:
Thread a piece of wire through the well nut. Fish the end up from behind the cowling. Hold onto both ends and push the well nut through the dash. Just have to get the lip started usually. The nut will pop off and be strung on the wire.
Spec is offline
post #8 of 21 Old 02-12-2015, 06:50 PM
mowcowbell's Avatar
Without going too far off topic, if you would get a Madstad bracket and windscreen, you can adjust the windscreen to your heart's desire with nothing more than two thumbscrews.
mowcowbell is offline
post #9 of 21 Old 02-12-2015, 08:40 PM
Ozmultis's Avatar
No need for any tools except the allen key to undo the screws, just undo them and then slowly pull out the rubber boot which holds the nut, its tight but comes out easily by hand, then remove the grommet for the hole you want and put the boot/nut there and the grommet in the now superfluous hole, and do that for all four and screw back in the allen bolts, it is very easy to do, all done from the from, no problem.
Andrew - Brisbane QLD Australia
White 2015 650 XT (beak, wire wheels, engine crash bars, hand guards, lower cowling) with SW Motech Centre Stand, Hepco Becker Pannier Frames and Caribou Commando Panniers, Safecase Topbox, Ravetech Mini Engine Guard, Ravetech radiator Guard, Ravetech GPS mount and Lifeproof Iphone case, Interphone Bluetooth in Helmet, and all soft luggage retained only by ANDY STRAPZ strapz and loops.
Ozmultis is offline
post #10 of 21 Old 02-13-2015, 09:22 PM
Hoo Dini's Avatar
Heat it up
I have moved them around quite a few times during warm weather & it was very easy. Trying to remove the well nuts below 50 degrees is tough. I layed a heating pad on the front cowling for 20 minutes & the well rubber softens up nicely.
Hoo Dini is offline
