Eastern Beaver PC8 Kit vs. DIY Installation - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 40 Old 02-09-2015, 01:53 PM Thread Starter
czkali's Avatar
Moral of this story is read AND follow the instructions on the Eastern Beaver site if you bought the PC8 "Kit", i.e. with pre-cut wires, relay, etc.
I dutifully searched the forum for ideas on how to install/mount my PC8. This lead me to several posts that confused me into thinking I could/should use the black rear brake light connector for control voltage to operate the relay for the switched circuits -- because after all it was so easily available and we all like "easy". It's obvious this won't work with the PC8 Kit because the Kit comes with a white two conductor connector and the black brake light connector has six conductors (five are wired on my bike).
Eastern Beaver does sell adapters that tap into the black rear brake light connector for other uses and possibly you could take control voltage from one of the leads (I didn't research it enough to know if this is true). But if you have the "Kit" stay the course and tap into the white rear brake switch connector under the coolant tank located up front under the rear of the fuel tank. Simply take off the two bolts holding the coolant reservoir in place to allow it to rotate enough to aid you in disconnecting the white connector and connecting the Kit's connectors into place. A long hemostatic clamp I found on a fishing trip helped me disconnect the connector as my hands didn't fit into the cramped space.
I hope this helps others to avoid the self-imposed confusion I had after searching PC8 related posts on the forum.
Here's a picture of my installation. You can see the black rear brake connector just above and behind the PC8.
2013 DL650
Farkles: Barkbusters Storm handguards | Givi 52L Trekker case | OEM side cases | OEM center stand | Weld86 skid plate
czkali is offline
post #2 of 40 Old 02-09-2015, 02:26 PM
Nice clean install.....well done!
post #3 of 40 Old 02-09-2015, 04:11 PM
zekester63's Avatar
Looks tidy, but unless I'm missing something, you still don't have anything connected to it yet, right? And that's where it starts to get messy.
So, with the PC8 mounted on it's side like that, is there still enough room to run wires to the ground connectors? And I would think that you'll need a wire loom or several zip-ties on any hot wires so they don't get tangled or caught on the seat post when removing or installing the seat.
I would probably do a few things differently if I had to do mine again. It works great, but isn't as tidy as some installations I've seen.
zekester63 is offline
post #4 of 40 Old 02-09-2015, 05:07 PM
Randy_K's Avatar
So if you did not buy the wiring kit you use the white wire that goes to the rear brake as the switched wire ?? Is that correct ?
Randy
2014 650 V-Strom , 2011 Husqvarna TE630, 1977 Canam 250 Qualifier, 1976 Yamaha TY175 Trials , 1978 Yamaha TY250 Trials , 1974 Suzuki RL250 Trials. < Past bikes... about 45 of them >
Randy_K is offline
post #5 of 40 Old 02-09-2015, 05:14 PM
The switched hot wire is not white. The white wire with a black stripe is the brake light hot wire. The PC8 would only be on when the brakes are on. The gray wire that feeds the tail light can work but be aware the PC8 will be on if the ignition is in the P position too. The brake light wire commonly talked about as a good switched hot for a relay trigger wire is the orange/green wire feeding into the rear brake light switch, not any wire leading off the switch.
post #6 of 40 Old 02-09-2015, 06:13 PM
my first thought as well
I ride: '05 Yamaha FJR1300 abs & '14 Yamaha Super Tenere ES
wife rides: '15 Yamaha Super Tenere
MrVvrroomm is offline
post #7 of 40 Old 02-09-2015, 06:19 PM
Works for me. Very little space is needed.
Glee under seat 001 by Greywolf, V-Strom rider, on Flickr
post #8 of 40 Old 02-09-2015, 06:33 PM Thread Starter
czkali's Avatar
I made sure it was off the bottom by at least my finger depth and I mounted it to the side with 3M dual lock tape (mushroom heads not hook and fabric) so I can easily take it off and move it slightly upward as needed. But I'm confident I can easily get the wires in as needed.
And if not, the dual lock tape will allow me to move it easily.
2013 DL650
czkali is offline
post #9 of 40 Old 02-09-2015, 06:38 PM Thread Starter
czkali's Avatar
zekester63,
Mine's a "wireless" installation -- it's all the rage these days with electronics you know.
Hopefully I'll get to wire it up soon. It took me months to get this far so we'll see what the schedule allows. But you're correct, the battle plan is perfect until the war starts.
2013 DL650
czkali is offline
post #10 of 40 Old 02-09-2015, 08:37 PM
zekester63's Avatar
Good idea with the dual lock! That's much better than typical Velcro. And if it's taken you this long, don't get in any hurry to finish everything all at once and you'll probably be happier with the end result.
