Adding a USB Cable or Power Port - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 02-08-2015, 10:06 AM Thread Starter
Keep_it_on_the_DL's Avatar
I picked up one of the Eastern Beaver accessory plugs that connects to the factory plug Suzuki put on the right side of the fairing. My original plan was to add a 12V outlet which would be primarily used to charge my phone that I have mounted above the instruments on Richland Rick's RAM mount.
The previous owner had a Garmin GPS power cable running through a small hole drilled above the instruments. If I ran my USB cable through that hole, I wouldn't have a bunch of cable flopping around in the wind.
My only concern is rain. Is having an exposed micro - usb plug going to pose any hazard to my electrical system if it got wet? At least with a power port, I can unplug the cable and close up the port.
2017 Honda Africa Twin DCT
2013 Honda CB1100
2015 Honda Grom
Keep_it_on_the_DL is offline
post #2 of 5 Old 02-08-2015, 02:17 PM Thread Starter
Nevermind...had to be reminded that the power outlet is needed for the appropriate volts/amps as my usb cable alone won't do that. Bad idea just to wire the cable directly to my electrical system.
2013 Honda CB1100
2015 Honda Grom
post #3 of 5 Old 02-08-2015, 04:53 PM
I use one of these:
Amazon.com: Black 5V USB Phone 12V Motorcycle Handlebar Handle Bar Clamp Charger Power Port Socket Set: Automotive
The USB port is powerful enough to charge my samsung victory but not my casio gzone (waterproof phone I use for GPS). I had to purchase this for the gzone:
Amazon.com: DROKĀ® Car Cigarette Lighter Plug Battery and Charging System Monitor Blue LED Voltmeter with USB Charger: Cell Phones & Accessories
It puts out enough amps to charge without issue.
supernac is offline
post #4 of 5 Old 02-08-2015, 08:30 PM Thread Starter
I ended up with a dual USB socket from West Marine and mounted it on the right side of the fairing. Radio Shack has a nice, short USB to micro USB cable that is the perfect length to reach.
2013 Honda CB1100
2015 Honda Grom
post #5 of 5 Old 02-09-2015, 02:45 AM
This:
http://amzn.com/B00GF0O0W8
USB has a weather proof cover.
It will charge 2.1A device.
FredBGG is offline
