Instrument display - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 02-08-2015, 02:30 AM Thread Starter
Instrument display
Hi my V is a 2013 DL650
Would love to hear from anybody who has had an issue with their speedo/ instrument display. A few weeks ago while out riding I got caught in the rain for a bout 3 hours. It was the first time I had ridden the bike in the wet. The speedo started dancing all over the place and the ABS light came on. I first thought it was mud in the front ABS tone wheel. But as I went on it got worse. The temp gauge wet to full hot yet the engine was cool and the fuel gauge showed empty but the tank was full. I cleaned the bike when I got home and did not ride for a couple of week, when I did the speedo started to work correctly again but after a while you could see a haze behind the glass. Well today speedo worked fine for about 4 hours then the rev counter stuck on
4,000rpm and the rest of the display went out completely.
If any body has had issue I would appreciate a reply and be interested to know if Suzuki came to the party and fixed it
Cheers
Mxteam is offline
post #2 of 12 Old 02-08-2015, 03:04 AM
Did you buy the bike new or 2nd hand ?
dazzarulz1990 is offline
post #3 of 12 Old 02-08-2015, 03:11 AM
BB63's Avatar
2013 bike should still be under warranty? Take it back and get them to fix it.
BB63 is offline
post #4 of 12 Old 02-08-2015, 05:42 AM
v-chops's Avatar
+1 Good luck
07 wee with the lot (nearly)
the most important part of any trip is getting home safensound
"travel by gravel and double your map" (in memory of a great Stromtrooper. Saturn5 R.I.P.)
v-chops is offline
post #5 of 12 Old 02-08-2015, 05:58 AM
OzCrow's Avatar
Sounds like a Regulator Rectifier? They played havoc with the electrics on many Honda's I've had. All sorts of funny shit happened but mostly when hot never cold and then they just died altogether. But Suzuki?
Actually a poor earth could do that too check the main earth lead is tight wherever it's mounted..
OzCrow is offline
post #6 of 12 Old 02-08-2015, 05:58 AM
K1W1's Avatar
As others have said it sounds like a straight out warranty issue to me provided the bike hasn't been crashed or somebody has fiddled with the instrument cluster or something.
K1W1 is offline
post #7 of 12 Old 02-08-2015, 09:08 AM
here have been some cases in the UK especially of water getting into the housing. All were replaced under warranty that I know of.
post #8 of 12 Old 02-13-2015, 01:42 AM Thread Starter
Finally
After two weeks Suzuki are going to replace the instrument cluster under warranty. At the moment its reading as engine over heating and the rev counter is off the clock.
Mxteam is offline
post #9 of 12 Old 02-13-2015, 09:56 AM
VSrider's Avatar
Don't forget to take note of the mileage from your old odo so you will have total mileage.
VSrider is offline
post #10 of 12 Old 02-13-2015, 10:39 AM
TinMan2's Avatar
Glad they are replacing an obviously poor unit. I suppose I've been lucky as I've owned many many motorcycles and scooters without water causing any gauges to go tits-up. Triumphs were known to zap your knee with an arc from the plug/plug wire in the rain but that's about it. I've drowned my Cruiser and the V-Strom in huge downpours to no ill effect. The replacement unit should do it.....good luck.....ride safe
TinMan2 is offline
