Mounted Rifle Hard Case - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 02-02-2015, 02:11 AM Thread Starter
interceptor430's Avatar
Yes, I mounted a hard case on my 2014 DL650.
Plans are to use it when bird hunting, and this Summer on my Alaska Trip
The Hard Case and bracket that holds it are for ATV's.....I just had to design an extra mounting plate... A bit of cutting, drilling, and welding... fun!
Pic was added below, finally.
interceptor430 is offline
post #2 of 12 Old 02-02-2015, 09:03 AM
TinMan2's Avatar
Driving into and through Canada with a rifle or firearm of any type can be a real pain. Be sure to register your ownership of the gun with US Customs PRIOR to entering Canada. I personally would UPS it to myself in Alaska and send it home the same way if I was riding to and from Ak. I carry my AR on my V-Strom but it is easy with the short barrel and collapsible buttstock(NOT into Canada). Breakdown shotguns are cake too. I've a friend that carries a Mosin 91/30 on his CanAm Spyder. Looks like a flag pole..................
TinMan2 is offline
post #3 of 12 Old 02-02-2015, 09:31 AM Thread Starter
Thank you TinMan2 for the info
File Type: jpg B9A4746A-31F6-4373-9646-0ED929C2D743.jpg (94.7 KB, 136 views)
post #4 of 12 Old 02-02-2015, 12:15 PM
I'm digging that! Have the same type case on my four wheeler and an extra mount. May hafta be a copy cat!
glock45fan is offline
post #5 of 12 Old 02-02-2015, 12:20 PM
TinMan2's Avatar
Quite welcome. I speak from experience as I was US and Canadian customs liaison for a US military detachment (Det 3, 425th MUNSS) stationed in Quebec. I made the run thru customs monthly and firearms even military in uniform on NATO orders caused major delays. Borders with allies are tough anymore..............ride safe.........Mike
P.S. nice picture came out well
TinMan2 is offline
post #6 of 12 Old 02-02-2015, 03:01 PM Thread Starter
Thanks... some 2 inch wide metal stock from Lowe's did the job fine...just drilled a couple holes for it to mount under the rear trunk...then it sticks out the right side for the base of the atv mount to bolt together. I doubled this piece for strength(tack welded together), and I used a ram mount underneath to keep it from flexing... both the rear and right side case tops open fine and miss the rifle case.... had about 1/4 - 1/2 inch clearance from both lids.
seems solid.
post #7 of 12 Old 02-03-2015, 10:28 AM
I was envisioning a rectangular case like mine. Your case is in-your-face rifle shape. Way cool!
post #8 of 12 Old 02-03-2015, 04:47 PM Thread Starter
I'm thinking to make another one...take it along as a spare on my trip.
No prob to make an extra one for you, if you wish.
let me know if you want one....
post #9 of 12 Old 02-03-2015, 05:40 PM
Very nice. I was just thinking about a way to mount one on my 2013 to carry a rifle.
mjl222 is offline
post #10 of 12 Old 02-04-2015, 09:20 PM
socalstrom's Avatar
There isn't anything more Murcan' than a rifle mounted to a motorcycle!! When I had my harley I wanted to get one of those ww2 engine guard mounted leather rifle cases. That would have been sweet.
socalstrom is offline
