At what mileage did you replace chain and or sprockets? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 41 Old 02-01-2015, 02:49 PM Thread Starter
TinMan2's Avatar
I would like to know the mileage at which you folks have had to change the chain and or replace the sprockets on the 650's. I'd also appreciate any info on parts cost.
Tell me how you know that the chain or sprockets need replacement.
Any information, pictures or suggestions gladly accepted.
Thanks in advance...........Mike
TinMan2 is offline
post #2 of 41 Old 02-01-2015, 03:06 PM
At what mileage did you replace chain and or sprokets?
I'm about due for replacement and I'm at 30,000 miles.
If your going the OEM route, I think it's much cheaper to get the chain and sprocket set and replace them all at once than get the items individually.
timspong is offline
post #3 of 41 Old 02-01-2015, 04:11 PM
Dragon1973's Avatar
I've got a new chain and front sprocket waiting for the snow to go away. My '13 has only 20k KMs. I only put 1/2 those miles on the bike, but I suspect the previous owner may not have done enough maintenance. The stock chain has developed a couple of kinks, and the front sprocket looks a wee bit warn, so I'll swap it out when I do the chain. The rear looks brand new; no signs of wear.
Picked up a DID XRing chain, JT sprocket and a couple of clip-links from Amazon. Shipped they were less than my local dealership.
Dragon1973 is offline
post #4 of 41 Old 02-01-2015, 06:10 PM
V-Tom's Avatar
Most people will find their chain and sprocket last somewhere between 20,000 and 30,000 miles if they follow the manufacturer recommendation.
On the other hand if you never waste your time and efforts cleaning the chain and instead only lube with every tank of gas and after every ride in the rain (I use Wurth HHS2000) you can expect your chain and rear sprocket to last somewhere between 41,000 and 50,000 miles. Front sprockets seem to be done between 35,000 and 40,000 miles.
..Tom
SMIDSY detailed report.
V-Tom is offline
post #5 of 41 Old 02-01-2015, 08:15 PM Thread Starter
TinMan2's Avatar
Wow, huge spread. I'm a Teflon chain lube guy and I do the second tank of gas vs the one tank that Tom does. I always lube after a dirt road or rain run.
Please keep the info coming guys and "thanks" to you folks that already posted!
What do you guys use for replacements? OEM or aftermarket? What price on parts are good prices. Its been quite a long time that I've run a chain final drive. I've been on shaft and belt final drives for a couple decades. ................Mike
TinMan2 is offline
post #6 of 41 Old 02-01-2015, 11:12 PM
US$180 or so is ball park for top quality chain & sprockets. DID, EK, RK, JT, Renthal, Regina are all very good. Lower tier but good value are the chains from the big wholesalers...Parts Unlimited, Bike Master, WPS. Pretty sketchy are the o-ring no-name chains off eBay.
If your chain has some stiff links, or lets you pull the chain away from the rear sprocket at the 3:00 position, or has red rust dust coming out of the rollers, it's time for a new one. Generally it's wise to renew the sprockets at the same time; worn sprockets wear a chain faster.
The DuPont yellow label chain lube is OK. The blue label stuff was weakened a couple of years ago and is no longer recommended for chains.
post #7 of 41 Old 02-02-2015, 01:21 AM
I had a kinked link at 24,000 miles. The sprockets were OK, but I replaced them along with the new EK chain I purchased from Blair at SV Racing. I was intrigued by the screw type master link offered with the EK chains. 10,000 miles on the new chain. Master link looks good.
deuce is offline
post #8 of 41 Old 02-02-2015, 01:38 AM
60,000k's. New front sprocket (only) @ ~35,000.
The old chain and sprockets would have gone further, but I blinked first. The only sign of problems when the chain was off was that it was uniformly stiff. You could lay it on the ground, lift it in the centre and the bend would stay there.
The new chain was like a wet noodle in comparison.
Pete
PeteW is offline
post #9 of 41 Old 02-02-2015, 04:39 AM
Don_T's Avatar
I did 25.600 miles on the OEM chain and sprockets.
At that point I had red rust dust coming out of the rollers and the chain needed frequent adjustment - the sprockets still looked good.
I replaced it with OEM sprockets and a DID X-ring chain. This combo have now done 15.550 miles. It still looks like new and I have only had to do one small adjustment to keep the chain slack within spec.
Based on previous experience with DID chains I expect it to last at least 35.000 miles.
I always replace chain and sprockets at the same time.
I second that.
Stiff links result in tight spots when controlling the chain slack.
Excessive wear on the sprockets is another indicator that it's time for replacement.
Yamaha XT1200Z '15 - www.bike-addict.dk - It's not what you ride but how you ride it unk:
Don_T is offline
post #10 of 41 Old 02-02-2015, 08:53 AM Thread Starter
TinMan2's Avatar
Great info guys! Appreciate all the tips and prices. I'm using the Yellow label DuPont chain lube so I guess I'm good-to-go there..........Mike
TinMan2 is offline
