EB ABS cutoff switch - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 01-27-2015, 07:52 PM Thread Starter
Bought a ABS cutoff switch from a member with no instructions. I know it is simple but cannot fine where to connect the 2 connectors to. I see the 2 ABS fuses under seat. Are the connectors at the bottom of those and which one does it go to. This set up already has a switch with it.
A pic would be great if someone has.
Thanks.
LeeK is offline
post #2 of 6 Old 01-27-2015, 07:55 PM
Do a search
Grey Wolf helped me with this issue some time ago. See if you can find it by doing a search.
DL650 2103
Farkles:
PC8 fuse box, EB headlight mod, Givi engine bars , Enduro Guardian radiator guard, B&B sump guard, MotoBrizz chain oiler, ATV high bars , (heated grips, EB ABS off switch, USB and cigarette plug mounted on Adventure Tech dashboard), Mitas E07 tyres, Bark Busters and Storm guards, Galfer braided SS brake line 2 inch extension, Cogent DDC fork emulators and .85 Kg straight wound springs.
xrman is offline
post #3 of 6 Old 01-27-2015, 08:19 PM
kiwi_outdoors's Avatar
motor fuse, not valve fuse
its in the middle of the three things (relay on left, your loc'n in middle, undisturbed switch on right)
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #4 of 6 Old 01-27-2015, 08:49 PM Thread Starter
Ran a search but could not find anything. So the two connectors go into the top of the little fuse cube. That is what I am looking for. I did not pull the yop but I assumed it was just a fuse.
LeeK is offline
post #5 of 6 Old 01-27-2015, 09:17 PM
You separate a connector near the battery positive post on a small red wire from the post and the switch wire ends plug into the connector halves.
post #6 of 6 Old 01-27-2015, 10:00 PM Thread Starter
Thanks, That is what I needed.
LeeK is offline
