ABS Sensor Guards - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 01-25-2015, 09:19 PM Thread Starter
Keep_it_on_the_DL's Avatar
ABS Sensor Guards
I was eyeing the Touratech ABS sensor guards for my 2013 Glee, but $60 for the set just seems ridiculous for a couple bolts, spacers, and aluminum. I figured I could make some, and while at Home Depot, picked up some aluminum angle stock for $4. Cut a couple of pieces to 1-1/2 inch long and notched one end. Rounded off the corners with a sanding drum and smoothed the edges with some 400 grit sandpaper.
For the longer bolts, got lucky and was able to use 2 of the 6 I replaced from the motor mount bracket when I put on my engine guards. The spacer on there is plastic and will be replaced with alloy spacers I found at aluminumspacers.com for about $7 shipped. They are 3/4" long, 3/4" OD, and 5/16" I'D (8mm bolt will fit). Not bad for $12 worth of materials and an hour of my time.
The front one could be a tad longer, so I may make another eventually. Right now, my next project are some removable extensions for the factory hand guards.
2017 Honda Africa Twin DCT
2013 Honda CB1100
2015 Honda Grom
Keep_it_on_the_DL is offline
post #2 of 6 Old 01-26-2015, 06:35 AM
DRD
nice
DRD
2013 Blue DL650
DRD is offline
post #3 of 6 Old 01-26-2015, 09:58 AM
New2Strom's Avatar
Great job. Put this on the top of my to-do list. Did you have any problems with the sensors being moved slightly and activating the ABS warning light?
If it ain't broke, fix it until it is.
Current stable: 2014 Harley-Davidson Ultra Limited FLHTK (Rushmore), 2014 Suzuki V-Strom 650, 2009 Honda Shadow Spirit 750 (Shaftie), 2006 Triumph Sprint ST 1050, 2003 Moto-Guzzi California EV 1100, 2002 BMW R1200C.
New2Strom is offline
post #4 of 6 Old 01-26-2015, 01:40 PM Thread Starter
Nothing yet. I think if the bolt securing the sensor is torqued properly, it shouldn't be an issue. One of the reasons I am swapping out the plastic spacers for aluminum is because the plastic spacers are a bit soft. That 8 mm bolt is burly enough to really squash down the plastic.
2013 Honda CB1100
2015 Honda Grom
post #5 of 6 Old 01-26-2015, 05:15 PM
vinnyvavoom's Avatar
Very nice for the price.
_______________________________________________________________________________
There are 10 types of people, those who know binary and those who don't.
What I ride now:
2013 Honda GoldWing (The Lady)
2014 V-strom 650 (The Mistress)
Previously: 07 Ultra Classic, 95 Softail, 80 gs450l
vinnyvavoom is offline
post #6 of 6 Old 01-26-2015, 06:04 PM
Well done son. Sure am proud of my sons creativity.
coral_snake is offline
