Radiator Fault - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 01-14-2015, 07:05 PM Thread Starter
Radiator Fault
I have searched and can't find any Radiator issues with the 2012 650.
I have what appears to be a manufacture fault with the radiator on my 2012 Wee. I have had it repaired (A large job to remove & refit).
The issue was on the back of the radiator where one of the fins had split. The repairer said it was a fault with the radiator. (2 months out of warranty so no help from Suzuki).
So after getting it fixed & putting it back together, 4 weeks later it has started to leak again next to the part that was fixed.
I had not changed the coolant prior to the first leak, so mixing coolants was not the issue. So I guess I either try to get it fixed again or bit the bullet & buy a new radiator. (3.5 hrs work to remove & reassemble I don't want to keep doing.)
Anyone else had Radiator issues?
TassieRide is offline
post #2 of 4 Old 01-22-2015, 10:08 AM
New2Strom's Avatar
Have you tried to find a used radiator? Search for motorcycle salvage. You never know.
If it ain't broke, fix it until it is.
Current stable: 2014 Harley-Davidson Ultra Limited FLHTK (Rushmore), 2014 Suzuki V-Strom 650, 2009 Honda Shadow Spirit 750 (Shaftie), 2006 Triumph Sprint ST 1050, 2003 Moto-Guzzi California EV 1100, 2002 BMW R1200C.
New2Strom is offline
post #3 of 4 Old 01-22-2015, 10:42 AM
chicago's Avatar
I had a leak on the radiator on my k75 (caused when I replaced the fan improperly). Local shop epoxied it and it was fine.
14 tooth for me
chicago is online now
post #4 of 4 Old 01-22-2015, 11:45 AM
Check ebay, they normally have at least one bike that is being parted out.
supernac is offline
Tags
manufacture fault , radiator issues
