Mod rear suspension when lowering? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 01-09-2015, 06:55 PM Thread Starter
I have lowered my 2012 650 by 3/4" front and back. Is still maybe a 'tad' too tall. My heels do not quite reach the ground. I am a novice rider and would be more comfortable with another 1/2" - at least whilst learning.
Question: if I lower the back an additional 1/2" (I don't believe the front can be lowered any more), do I need to modify / restrict the travel of my rear suspension? I saw a post from a few years back where Grey Wolf had mentioned this and posted a picture of a worn-through fender? What about when I add a passenger?
Thanks mucho!
Papa-Coco
papa-coco is offline
post #2 of 7 Old 01-09-2015, 07:21 PM
You can lower the rear as much as 1-1/8" on a Wee with no fender danger. In fact I hadn't thought about it before but the longer shock on the Glee may allow even a but more.
post #3 of 7 Old 01-09-2015, 07:31 PM Thread Starter
Super! Thanks for the quick reply.
post #4 of 7 Old 01-10-2015, 02:03 PM
Or, cut down the seat. Remove the cover, carve out the foam, replace the cover.
post #5 of 7 Old 01-10-2015, 11:05 PM Thread Starter
Thanks. I just ordered new lowering links, so I guess I won't try my hand as an upholsterer :-). Have you done this? If so, you must be happy with the result.
Ron (papa-coco)
post #6 of 7 Old 01-11-2015, 12:23 AM
jerryscove's Avatar
My experience
My first bike, and only bike, is a 2013 DL650A. At first I thought the bike was too high, top heavy but now after a full year of riding, all seasons, and without doing anything to the bike it all seems fine. I'm still discovering this bike's capabilities as I gain experience.
Here's what I'd want for the bike...I wish Suzuki would provide a quality upgrade option at time of purchase for both suspension and brakes. I'll upgrade my suspension when the current factory supplied wear down enough to justify replacement.
Regards
jerryscove is offline
post #7 of 7 Old 01-11-2015, 07:30 PM
I took the lugs of my set, then boght the lower seat and took the lugs of them , then put on the lowering links ,
Has i've got used to it i' don't know if the suspension has dropped or i'm just more used to it , . But i put the lugs back in the lower seat . did'nt make a differenc ,
I got sick of the lower seat too hard , so put the normal seat back on and its still good but more comfortable , now i put the lugs back in that seat and its still good .
Put the lowering links on ride it and give it time i think you will be fine , if not don't stuff up your seat just buy a lower seat you can always sell it later , .
If the lower seat and lowering links still leave it to uncomfortable and hard to handle ,, change bikes .
coneye is offline
Tags
lowered , lowering , suspension
