Winter storage battery charging - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 01-01-2015, 05:21 PM Thread Starter
I have this charger> http://www.amazon.com/Deltran-Batter...ender+chargers <& I don't leave it connected all the time. My bike is out doors under the deck awning where I leave it uncovered. That area is pretty free from the wet stuff but not totally so I only hook up the charger when I know it will be dry for a few days. Say once every few weeks. Is that OK to maintain my battery or should I pull the battery & leave it indoors hooked up all the time. I'm needing for some advice please guys.
Dantrax is offline
post #2 of 17 Old 01-01-2015, 06:02 PM
Topping it off every few weeks is fine.
post #3 of 17 Old 01-01-2015, 06:20 PM Thread Starter
Cool thanks greywolf
Dantrax is offline
post #4 of 17 Old 01-02-2015, 01:10 PM
Hammerfer's Avatar
probably not a big help for you but maybe to someone else. i use one of these:
1.5 Watt Solar Battery Charger
i throw the charger and battery on the dash of my RV and it does a nice job of keeping a full charge on it over the winter
Hammerfer is offline
post #5 of 17 Old 01-02-2015, 01:50 PM
If you are really worried, just pull the battery, it's not that difficult. Or, get a long cord (someone makes a 25' with the ends that will work) and leave the battery in the bike.
I leave my battery in/on my bike (southern nh) all winter, although about once a month (hopefully more) I get out on it, with no issues with cranking power. The only time the battery ran down was when I locked my handlebars and turned key one turn to far and the rear light ran it down.
danhikeski is offline
post #6 of 17 Old 01-02-2015, 02:03 PM
I just start mine every other week and let it run until its up to temp. Usually about 15 minutes.
2013 Vstrom 650. White, CL-855 bags. Bags connection City tankbag. Givi Airflow. Augustus Deflectors. Bar end mirrors. JC Whitney top case.
brcol is offline
post #7 of 17 Old 01-02-2015, 02:31 PM
DRD
Battery tender jr plugged in 24/7.
DRD
2013 Blue DL650
DRD is offline
post #8 of 17 Old 01-02-2015, 04:51 PM
Someone will be along and say that while it might keep your battery charged, it'll kill the inside of the engine with all the moisture that'll build up, and won't get evaporated away, and repeat
Oop North John is offline
post #9 of 17 Old 01-02-2015, 08:22 PM
Newstrom48's Avatar
I remove my battery and leave it on a wood shelf in my unheated garage for the winter. I don't put any battery charger/tender on it. Charge it up and start the bike in April/May.
Newstrom48
2009 DL1000
Too many Farkles
Newstrom48 is offline
post #10 of 17 Old 01-02-2015, 10:00 PM
Stalky Tracker's Avatar
+1. Usually on in early November and off, hopefully, in April.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
