Flush rear brake - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 12-29-2014, 03:17 PM Thread Starter
dravnx's Avatar
Flush rear brake
Is it possible to do a rear brake flush without removing the rear luggage rack and plastics IAW the shop manual?
L2 DL650 Adventure
bike X miles=smiles
smiles ÷ bike=miles
smiles ÷ miles=bike.
It's simple math.
https://www.directavionics.com/
dravnx is offline
post #2 of 7 Old 12-29-2014, 06:08 PM
H8-3Putts's Avatar
I accessed the rear reservoir without taking the rack and side panel off, but it was a little awkward and really limited working space. I needed to use a funnel to add fluid and had to be really careful putting the reservoir cover back on. I didn’t break/bend/crease any of the panels, but I guess that would be a risk.
I recently flushed my rear brakes and took the rear rack off, etc. Made access pretty easy.
I think you "could" loosen the panel and provide some access, but it's a lot easier just to take them off IMO.
H8-3Putts is offline
post #3 of 7 Old 12-29-2014, 06:34 PM
fortp's Avatar
Be carefull to not spill brake fluid on painted surfaces.
fortp is offline
post #4 of 7 Old 12-29-2014, 11:04 PM
Bought some cheap epoxy syringes on ebay. With the seat off you can drain it or top it off with no problems. Did not have to remove anything else.
LeeK is offline
post #5 of 7 Old 12-30-2014, 10:58 AM
Maybe LeeK is on to something. I'd hate to mess with all the luggage rack mounts. My bike really need some fresh juice!
Gold star on the collar and an Atta Boy!
post #6 of 7 Old 01-31-2015, 10:27 PM
A carefully drilled hole in the right side of the battery box allows you to use a screwdriver from inside the battery box to remove the screw that connects the black frame cover, which covers the rear brake resevoir, to the orange tail piece.
LongEz is offline
post #7 of 7 Old 02-01-2015, 07:30 PM
Great idea on the battery box hole. Did it today works great. Used a step drill. Thanks.
LeeK is offline
