12 O'clock Labs SpeedoDRD - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 12-20-2014, 11:15 AM Thread Starter
Luma's Avatar
Has anyone installed on their bike the 12 O'clock Labs SpeedoDRD calibrator?
I am wondering if I will have to remove the tank and possibly the air filter to get to the respective connector. I understand it is somewhere higher up on the engine's right hand side.
How does it work for you, I hope it doesn't affect in some way the FI setting?
2016 Honda Africa Twin
Luma is offline
post #2 of 7 Old 12-20-2014, 11:40 AM
It works fine. The connector is reachable from the left side with no parts removal required. On my Glee, the black speedo connector was near the white connector from the fuel pump.
post #3 of 7 Old 12-20-2014, 03:14 PM
It worked well. I was surprised how good I felt seeing the correct speed instead of doing the mental correction to the speed. I haven't decided if I'll splice mine into the wiring of the Vee2--there is no connector to hook it to.
post #4 of 7 Old 12-21-2014, 12:40 AM
Texan's Avatar
Piece of cake. It calibrated my speedo perfectly. However I assumed that because the speedo was previously reading 8% high so was the odometer, i.e. racking up 8% more miles. That wasn't the case, it was accurate. Once I lowered the speedo to read accurately the odo is off, low by the same percentage and as a result the mpg display.
2016 BMW R1200RS
2016 Suzuki GSX-S1000F
2013 Suzuki DL650.. SOLD!
2017 Suzuki DL650 as soon as they hit the sales floor.
Texan is offline
post #5 of 7 Old 12-21-2014, 09:52 AM
Vhawg's Avatar
So the trade off is accurate mileage and MPG?
2013 DL650
2003 Victory Touring Cruiser
1983 Seca 900
1980 XS 850 triple
1971 Dunstall Norton
1970 Triumph Trophy 500
1972 Honda Trail 90
Vhawg is offline
post #6 of 7 Old 12-21-2014, 10:03 AM
No. Since the stock instruments read about 8% high on the speedo and about 2% high on the odometer, making the speedo accurate will make the odometer read low as both instruments read the same sensor pulses. https://www.stromtrooper.com/dl650a-2...012-dl650.html
post #7 of 7 Old 12-27-2014, 01:17 AM
Texan's Avatar
That's been the case for me, yes.
2016 BMW R1200RS
Texan is offline
