OEM Adventure side rack - indentical to SW Motech rack or made by them only. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 22 Old 05-27-2014, 01:07 PM Thread Starter
I bought a complete kit of Suzuki side cases to put on another bike that already has a SW Motech rack on it.
So I will be left over with the racks for the bike that I am selling and I been getting a few questions.
Is the OEM rack the same rack you can buy from SW Motech or did they make it differently for Suzuki?
jfman is offline
post #2 of 22 Old 05-27-2014, 01:42 PM
I believe the side racks are standard SWMoto products, in that they use the available same mounting brackets and are set up to accept all standard luggage. I know they will accept the Givi monokey mounting kit. The OEM racks I think were modified to add the mounts for the suzuki specific pannier locking latch and the Reflector relocation tabs. But I have not seen a standard SWMotech set up to do a side by side comparison.
DualSport Rider 650
2012 DL650A-L2 ABS ADV
2003 KLR650
DSRider650 is offline
post #3 of 22 Old 05-27-2014, 05:02 PM Thread Starter
Originally Posted by DSRider650 View Post
The OEM racks I think were modified to add the mounts for the suzuki specific pannier locking latch.
So the Traxx side cases made for Suzuki have different mounting points than all other regular Traxx?
jfman is offline
post #4 of 22 Old 05-27-2014, 05:40 PM
oink's Avatar
That's what they did to the Suzuki branded SW Motech Trax top box.
oink is offline
post #5 of 22 Old 05-27-2014, 10:17 PM Thread Starter
That is kind of a dick move on their part. Ill see when i get it together with the bike.
I guess I should have researched it better before buying.
jfman is offline
post #6 of 22 Old 05-27-2014, 10:59 PM
I don't know for certain, but the top rack was definitely spec'd to the proprietary Suzuki luggage. I also spoke with a Twisted Throttle rep recently. He said the Suzuki stuff was a custom order and built to a price point. The implication being the factory crash bars are made of different material and not as good as the normal SWMotech offerings. I don't think the diff is that big and the OEM package is serving me fine after I made an adapter for my Givi top case.
DualSport Rider 650
2003 KLR650
post #7 of 22 Old 05-28-2014, 04:33 AM
For the side cases:
Racks are near the same, but not equal.
Suzuki rack is wider, in order to avoid relocating the blinkers.
With SW-Motech is mandatory to move them because the Trax cases will fold them. I'm not sure but I think if you don't relocate the blinkers the cases won't attach to the panniers.
Attachment points are sightly different between the two racks. SW-Motech mounts under the handles for the passenger. Suzuki rack must be mounted over the same rack.
Apart from that, you can use Suzuki Boxes in any of those two racks. Trax cases and Suzuki OEM cases are the same, they just rebranded them. Because of this, boxes are fully compatible.
I hope you can understand my not-so-good english.
boni_y_yo is offline
post #8 of 22 Old 05-28-2014, 09:15 AM
Originally Posted by boni_y_yo View Post
For the side cases:
Can you use Trax boxes on the Suzuki rack?
2012 DL650 Adventure - Black
OEM Hand guards, OEM Heated grips, Stroma Center Stand and Shifter, SV Racing Frame and Swingarm sliders, Eastern Beaver power distribution, Skene Visibility Lights
Pele2048 is offline
post #9 of 22 Old 05-28-2014, 10:06 AM Thread Starter
For the side cases:
Thank you!
Thi8s is the answer I was hoping for.
jfman is offline
post #10 of 22 Old 05-29-2014, 04:37 AM
Side cases are fully compatible. They are the same but with other logos.
Yes, you can. Also, you can use Suzuki boxes in SW Motech Trax (what I do).
Don't know about the top case.
