Riser Problem? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 05-26-2014, 10:09 AM Thread Starter
Riser Problem?
I installed risers on my 13, removed the brake cable clamp from lower triple clamp and all seemed well. I was able to turn to lock on both sides.
After starting, when I turn hard to the left, engine rpm rises. This doesn't seem to be an issue when running on the street.
Is this a concern, am I doing any damage? TIA Ian, Iowa
ianbh is offline
post #2 of 3 Old 05-26-2014, 10:40 AM
It's pulling on the throttle cable.
post #3 of 3 Old 05-26-2014, 02:17 PM Thread Starter
Never mind, I loosened the throttle cables (where they go into throttle tube), lowered them and all is good. I had raised them for additional clearance for the Bark Busters. Ian
ianbh is offline
