Issue with Givi AirFlow AF3101 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 05-20-2014, 06:53 PM Thread Starter
Harry Dresden PI's Avatar
PROBLEM (Shield slowly lowers itself) ...
Perhaps I clean and polish my windscreen too much, but recently on my 2012 DL650a the Givi Airflow AF3101 (Which I love) slowly lowers itself after about a 100 mile ride.
Due to lobe bug splatters I weekly have been removing the top screen to clean bug guts that collect on both outer and inner screen surfaces
Top outer screen moves from 1/2 up to almost all the way down.
(100 mile ride 30 - 80 mph)
Clamps seem tight ...
Action Plan:
1. Likely will check the clamp nuts for tightness
2. May use something to clean / rough up the sliding channels
ANYONE ELSE SEE THIS ISSUE?
ANYONE ELSE ALREADY FIT THE ISSUE?
Thanks in advance ...
#045 Harry Dresden PI
Harry Dresden PI is offline
post #2 of 14 Old 05-20-2014, 06:56 PM
Matthew6279's Avatar
Hmm I have not seen/had that issue. Approx 300 miles on my screen so far.
Current:
2014 V Strom 650 - V46 topcase, E41 side cases, Suzuki lower fairing, Givi Airflow windscreen, Ram mount handlebar mount and pda case for my phone, 12v power at handlebars, Dan Vesel Highway bars with Rivco pegs, Dan Vesel passenger peg relocate with Kuryakyn bolt on floor boards, Adventure Tech fork brace, Extuff helmet hooks, Ram mount cup holder, 12v/usb/voltage meter all in one mounted to brake reservoir, Happy Trail center stand, SV racing foam grip covers, Kolpin handlebar mitts, Moose Contour hand guards.
1982 Honda XL 250
1981 Honda XL 185
1990 KX 250
Polaris Sportsman 570 touring
Previous:
2006 Yamaha R6
2003 Yamaha R1
2002 Yamaha R1
2001 Yamaha FZ1
1974 Honda CB360
1982 Honda CT200
1988 Honda CR 80
Matthew6279 is offline
post #3 of 14 Old 05-20-2014, 06:58 PM
DGrav's Avatar
I had that issue. I adjusted the nuts on the clamps and everything has been fine since.
Musician, backpacker, Mt. Biker, learning how to be a motorcyclist.
DGrav is offline
post #4 of 14 Old 05-20-2014, 07:01 PM
chirosyd's Avatar
I had this screen on my '11 Wee for 20000miles with zero trouble. I would check the nuts to be sure they are at the proper tightness. I did tighten them once or twice to be sure the top shield held in place. With the two levers down, there should be zero movement of the upper shield. I am sure you will find this.
A great product, and if they make it for my Vee2, I may buy it even though the stock shield is very good.
chirosyd is offline
post #5 of 14 Old 05-20-2014, 10:29 PM
mountainpete's Avatar
Similar thing happened to me on a multi-day ride. Tightened the clamp nuts = fixed.
2012 DL650 EXP
Designed for outdoor use
mountainpete is offline
post #6 of 14 Old 05-20-2014, 11:17 PM
It seems to be unanimous - the problem is your nuts.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #7 of 14 Old 05-21-2014, 05:32 AM
DaveinNC's Avatar
Adjust your nuts, they will stop slipping. I had to loosen one of mine out of the box to get it to close.
"Dave"
DaveinNC is offline
post #8 of 14 Old 05-21-2014, 08:49 AM Thread Starter
Tighten Those Nuts ...
Wife agrees the problem is ... I am nuts or my nuts ....
Thanks all will tighten them today
post #9 of 14 Old 05-21-2014, 09:42 AM
bosnjo's Avatar
Mine is fine after 4000 miles. And... I don't need to mess with my nuts...
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #10 of 14 Old 05-21-2014, 10:07 AM
the nuts problem tend to present itself at the most inopportune moment !
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
