Cruise control issues - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 23 Old 05-12-2014, 05:17 PM Thread Starter
I just got done installing the rostra cc unit on my 2012... All. Works now but my FI light is blinking and the bike won't idle down. Any thoughts?
Jessesmith121 is offline
post #2 of 23 Old 05-12-2014, 05:44 PM
I'll bet something in the linkage is keeping the throttle from closing. See FAQ: Dealer Mode & FI Error Codes to read the error code. The connector is under the seat on the lift side near the back. It's the white connector in the picture. Remove the cover to access the connections.
post #3 of 23 Old 05-12-2014, 07:36 PM Thread Starter
C65 is the code that is pulling up... The bike runs okay but will not idle down.. Pulled it all apart and the throttle bodies are free with no obstruction.
post #4 of 23 Old 05-12-2014, 07:56 PM
A C65 is idle speed out of range which you already know. So you're sure there is slack in the Rostra cable. There are a lot of moving parts that get moved by the throttle cable movement. I still think the most likely cause is one of those moving parts hitting something. You can try an ISC reset if you are sure there is no physical interference.
1) Turn the ignition switch to the OFF position.
2) Remove the seat.
3) Put the bike in dealer mode. FAQ: Dealer Mode & FI Error Codes
4) Turn the ignition switch to the ON position.
5) Turn the ignition switch to the OFF position.
6) Then, wait more than 5 seconds.
The ISC valve automatically is set at the PRE-SET position.
7) Take the bike out of dealer mode.
post #5 of 23 Old 05-12-2014, 07:59 PM
Make SURE there is slack in the cruise control cable where it attaches to the throttle linkage.
realshelby is offline
post #6 of 23 Old 05-12-2014, 08:37 PM Thread Starter
I removed the tank and the air box again... There is absolutely no interference in the throttle... I did the valve reset and no joy... Still idling high and the FI light comes on... This is really frustrating...
post #7 of 23 Old 05-12-2014, 09:10 PM
Again, are you sure there is slack in the Rostra cable.
post #8 of 23 Old 05-12-2014, 09:34 PM Thread Starter
Yes there is ample slack in the cruise cable
post #9 of 23 Old 05-12-2014, 09:53 PM Thread Starter
Here is a pic of my slack...
post #10 of 23 Old 05-12-2014, 10:50 PM
Pull that rod's connection off the joint and see if the mechanism moves.
