Mirror adjustment, top pivot - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 05-09-2014, 03:44 PM Thread Starter
Dragon1973's Avatar
Hi Everyone.
Just got my new (to me) 2013 yesterday... I can't seem to figure out adjusting the right hand mirror. The pivot at the top of the mirror arm(?) which should allow it to pivot the mirror to get a higher/lower view seems to be stuck. The left side is fine: tight but moveable.
I need to pull it in so that it's closer to me too. It looks like the pivot at the top should do that too, but it actually ends up loosening the threads on the bottom of the arm. I do know that the threads are backwards (thanks to this forum) so that makes sense that by pulling the right mirror just loosens it. But each time I push it back to re-tighten the threads, the mirror seems to go further out.
I'm trying to get it so I can just see my arm in the edge of the mirror so I have perspective of what I'm seeing in the mirror. but right now I can't see my arm at all, and it's to high... can't even see the ground unless I lean forward.
If that top pivot would move it would solve my problemo. Is it seized? or is there a set-screw or something that I don't see? Mind you I have not looked TOO closely at it yet. I just got it yesterday, and had to work today...
Thanks
Dragon1973 is offline
post #2 of 9 Old 05-09-2014, 03:46 PM
StarChamp's Avatar
Sounds like you need to raise the rubber cover to get to the locking nut?
StarChamp is offline
post #3 of 9 Old 05-09-2014, 03:49 PM Thread Starter
Dragon1973's Avatar
but, that's at the bottom of the arm, attaching it to the handlebar. Or, is there one at the top too, that attaches the mirror to the arm itself?
post #4 of 9 Old 05-09-2014, 03:56 PM
StarChamp's Avatar
Mis-read part of your thread; I think you're right that the mirror-to-arm fitting is just a pressure/friction fitting, with no locking mechanism. Sounds like the mirror might already be at the far end of its range of motion? Maybe the arm needs to be re-aligned at the perch to get some adjustability back.
post #5 of 9 Old 05-09-2014, 03:59 PM Thread Starter
Dragon1973's Avatar
It must be seized then. It's not that it won't move one way... it will not move at all, in any direction.
post #6 of 9 Old 05-09-2014, 04:04 PM
Sigh! Doesn't anybody read the sticky threads. They are there for a reason. https://www.stromtrooper.com/dl650a-2...2012-650s.html
The bottom has to be aligned first. Then the small adjustment at the top can be done.
post #7 of 9 Old 05-09-2014, 04:12 PM Thread Starter
Dragon1973's Avatar
Ok, that's my bad, I apologize... I usually always read the first page of a thread, but rarely do I proceed further because it gets to be a lot of useless comments. Especially sticky threads that get to be a million pages long. It's too bad there is good info many posts into the thread forcing readers to have to read all the useless chatter between.
I read this one front to back now and see how I can adjust the in-out. But, if the top was pivoting, then I would not have this issue to begin with... is it really just a friction fitting that's probably rusted up now?
post #8 of 9 Old 05-09-2014, 05:30 PM
The top fitting is a friction fit with very limited movement. Most of its movement is rotational, allowing an up and down movement. The side to side movement is nearly non existent.
post #9 of 9 Old 05-09-2014, 07:06 PM Thread Starter
Dragon1973's Avatar
Alright... got the bottom pivot adjusted where I want. And now that it's there, maybe the top is OK. Once I can ride it again we'll see.
tx
