Ambient Temp Indicator - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 26 Old 05-08-2014, 03:32 AM Thread Starter
BKP
BKP's Avatar
Anyone here use their ambient temp gauge (it alternates with the clock after a long press of the left outside switch)?
I like knowing the temps for my own reasons... but, this thing is anywhere from 4 to 8F high. I wouldn't mind if it was consistently 8 high -- then I could at least extrapolate. But, it varies. I bought a a nice $45 Kuryakyn Black Marlin's Talon temp gauge, but that sucked almost as badly...
Anyone else have any comments on this? I know the sensor is replaceable, but it's a pain.
[B][I]Barry[/I]
2017 Pearl White 650[/B]
AdventureTech lowering links and GPS mount
AdventureTech +2" SS braided brake line
Madstad windscreen
GPI spools, SW Motech risers
Givi XS307 Tanklock bag and Givi 46L top case
Suzuki hard case saddlebags
BKP is offline
post #2 of 26 Old 05-08-2014, 03:44 AM
Retaite's Avatar
No, but I can tell you what it looks like
The sensor removed.
Long story :mrgreen:
Retaite is offline
post #3 of 26 Old 05-08-2014, 03:45 AM
It's not the sensor, it's where the sensor is positioned.
Pete
PeteW is offline
post #4 of 26 Old 05-08-2014, 04:12 AM Thread Starter
BKP
BKP's Avatar
Pete
You mean where it's positioned in relation to components that might give off additional heat?
That would make sense, however, that wouldn't explain the temp fluctuations from true (unless the sensor was hanging loose... bouncing around).
[B][I]Barry[/I]
Madstad windscreen
BKP is offline
post #5 of 26 Old 05-08-2014, 06:20 AM
LordSmoke's Avatar
Don't have an OEM therm. on the Wee, but I share your interest in ambient temp. Installed this Lascar unit on my scooter:
General observations...
A thermometer without a remote sensor is nearly useless. A bit of sun will drive the reading up by dozens of degrees.
Sensor position is important. On the scooter, mine is in the airstream under the nose with the radiator. No problem when moving, but temp rises rapidly when stopped in traffic.
So, I would try to check/adjust sensor position and be don't expect accurate readings if stopped and sensor is exposed to sun or engine heat.
2014 BMW R1200GSW (APR14 - )
LordSmoke is offline
post #6 of 26 Old 05-08-2014, 06:22 AM
Don_T's Avatar
Speed and wind direction effects the reading of the sensor.
Yamaha XT1200Z '15 - www.bike-addict.dk - It's not what you ride but how you ride it unk:
Don_T is offline
post #7 of 26 Old 05-08-2014, 07:52 AM
I've only used it on occasion, usually when leaving a campsite in the morning, but in reality, I already know when it's hot or cold out
bikerfish is offline
post #8 of 26 Old 05-08-2014, 08:01 AM
Yea the thermometer is about as accurate as the speedo.I just put on another layer when I start shivering.
coaststrom is offline
post #9 of 26 Old 05-08-2014, 08:34 AM
We have two identical 2012's and they read identical temperatures, both 3-4 degrees above ambient when ambient is 50-90 degrees. This variance increases from zero as the bikes warm up, suggesting it's a result of where the thermocouple are placed. The fact that we're seeing the same variance suggests replacing your sensor wouldn't change anything.
dkayak1 is offline
post #10 of 26 Old 05-08-2014, 08:38 AM
cpd419's Avatar
Mine reads fairly close according to bank signs and what not.
2013 DL650
cpd419 is offline
