DIY sport / short windshield - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 05-07-2014, 11:59 AM Thread Starter
Following CecilSaxon instructions (here), I made my own sport / short windshield. I gave it a test ride at various speeds and so far I like it very much: minimum airflow on the chest, no buffeting and noise level is acceptable. $45 total cost ($41 for the Suzuki OEM screen and $4 for paint).
I used Krylon Fusion for painting the interior black. Will see how it will hold.
nster is offline
post #2 of 10 Old 05-07-2014, 12:14 PM
Nice! I have a spare stock windscreen and was considering doing something like this. I think now I'll have to, I did my commute with no windscreen the other day just to see what the air was like "raw" and there's way too much on my chest. I'm trying to get the "bubble" to cut off as high as possible without buffeting my helmet, but even at the lowest setting the stock windscreen needs to lose 6-8". This might be just the ticket.
Shaggy is offline
post #3 of 10 Old 05-07-2014, 12:17 PM
everready's Avatar
How did you actually cut the plastic? Coping saw, Dremel?
Al
2013 DL650A "Blue"
Previous bikes: '78 CB750F, '86 Nighthawk S, '87 EX500, '85 Sabre 700, '93 Katana 600, '75 Rupp 80, '78 DT250, '88 TT225, '89 CR250
everready is offline
post #4 of 10 Old 05-07-2014, 12:35 PM Thread Starter
Dremel
Al
I used a Dremel tool with the EZ Lock wheel for plastic. I taped both side of the screen with 3M masking tape before cutting (protects from scratches and helps to get rid of the melted plastic after you are done cutting).
nster is offline
post #5 of 10 Old 05-07-2014, 01:14 PM
everready's Avatar
Thanks! I might just have to give it a go.
Al
2013 DL650A "Blue"
post #6 of 10 Old 05-07-2014, 01:18 PM
Al
I have cut down windshields with a coping saw and it works very well. As stated before use blue masking tape to protest the shield and after cutting use progressively finer sandpaper to smooth the edges, ending up with 800 grit wet sand paper. You can make the edges look like glass.
My two wheel history
'72 Honda XL250
'73 Yamaha RD350
'75 Yamaha XT500
'76 Yamaha XS650
'78 Yamaha XS750
'77 BMW R100/7
'76 Triumph Bonneville T140-V
'07 Triumph Bonneville America
'11 Suzuki V Strom 650
Johnny Bravo is offline
post #7 of 10 Old 05-09-2014, 05:27 PM
Question
Sweet, I was just thinking of ordering a shorter windshield. Think I'll cut my stock one down (already have an after market taller shield) for use until winter temperatures arrive.
Can you share the dimensions? Particularly the length along the center line from bottom to top and the length of the sides?
Really want to get my strom to ride with nice clean air around the helmet to reduce the wind noise.
[URL=http://www.fuelly.com/driver/flakrat/dl650][IMG]http://badges.fuelly.com/images/sig-us/249414.png[/IMG][/URL]
flakrat is offline
post #8 of 10 Old 05-09-2014, 09:45 PM Thread Starter
11.5 inches from top to bottom and 8.5 from the widest point on the side to the top. You might also look at CecilSaxon's post for the overall shape: his is flatter, mine pointy. Not sure which one works best.
CecilSaxon's short screen
nster is offline
post #9 of 10 Old 05-09-2014, 10:35 PM
Looks nice. Did you rough up both sides? 0000 steel wool? Which set of mounting holes did you use?
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #10 of 10 Old 05-09-2014, 11:29 PM Thread Starter
Yes, both sides with fine steel wool. Started with circular motion and finished with vertical passes.
I tried the lowest and middle position and prefer the latter. YMMV, of course. For reference, I am 5'8".
nster is offline
