Resonance - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 05-06-2014, 03:41 PM Thread Starter
kmsz1969's Avatar
Resonance
Resonance... What a strange phenomenon on bikes.
When I had my Versys some years ago I installed a SW-Motech Crashbar and after that, at certain RPM the bike begin to vibrate... a lot... then I discover resonance in my bike at those RPMs. As I was getting mad because of that vibrations I changed it by another unit from Hepco & Becker and the problem disappeared. Apparently the different design did not cause such as troublesome vibrations.
I recently installed my SW-Motech topcase in my VStrom and now I can perceive the same strange phenomenon. A certain RPMs, the topcase starts to vibrate creating a very deep sound, as if the bike had an aftermarket exhaust (but not vibrations on the handlebar or other place) ... I hope it that sounds diminishes when I put some clothes inside...!
kmsz1969 is offline
post #2 of 9 Old 05-07-2014, 12:42 AM
Yes, the frequency will change with load.
Ride safe!
V Strom DL650 - 2013 Riding
V Strom DL1000 - 2007 Sold
Honda Shadow 750 - 2000 Sold
Pauloxxi is offline
post #3 of 9 Old 05-07-2014, 04:57 PM
You could also add some dampers to the mount. I cut out some silicone washers and added them around the mounting bolts between the mounting plate and my bike and it cut down topcase vibrations.
Mimo256 is offline
post #4 of 9 Old 05-07-2014, 05:05 PM
Banned
resonance is a function of mass, so I filled my GIVI crashbars with metal BB's to solve the vibration problem.
Rashnak is offline
post #5 of 9 Old 05-07-2014, 08:47 PM
I had buzzing in my Shad 40 after a new install. Installed isolators from Grainger. never another sound in 2 years, 12k miles.
https://www.flickr.com/photos/275138...7644516033856/
Tony D P is offline
post #6 of 9 Old 05-08-2014, 10:39 AM Thread Starter
kmsz1969's Avatar
YouŽre right... some rubber isolators could be the solution... IŽll try it.
kmsz1969 is offline
post #7 of 9 Old 05-08-2014, 11:14 AM
zekester63's Avatar
Rashnak, do you remember how many BBs you had to use? I've made some efforts to reduce the vibrations with o-rings at the connection point, etc., but right at the sweet spot in RPMs, it's still pretty annoying.
zekester63 is offline
post #8 of 9 Old 05-08-2014, 01:03 PM
Banned
it's been 5 troublefree years...
but as I recall, the GIVI crash bars took about 6-8 ounces of BB's to fill.
Because I filled the bars from the bottom, I had to find a way to keep the BB's from falling out as I installed the bars back on the bike. So I used a little dab of that expanding foam they sell as home insulation to fill cracks. Once that hardened I installed the BB filled GIVI bars and have not heard any vibration since.
Rashnak is offline
post #9 of 9 Old 05-08-2014, 04:04 PM
Cool BB/foam damper
That foam with BB's mixed in would tend to act as a damper, especially if it ends up out where the motion is greater. I think it would be worthwhile to try to enhance this effect, by stuffing foam and BB's together into the tubing.
Trepidator is offline
