Tire pressure - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 05-04-2014, 09:45 PM Thread Starter
johnnail's Avatar
Tire pressure
What kind of air pressure do you run? I'm a big guy--230lbs--and tend to go a little over the pressures listed on the swingarm. BUT, I get a lot of center tread wear.
How about you?
Everywhere you go, there you are!:biggrinjester:
johnnail is offline
post #2 of 8 Old 05-04-2014, 10:05 PM
Based on some things I've read here, I'm running 2-3 psi above OEM recommendation. Have never run low pressures on this bike, but from experience with other bikes I know the handling and turn-in can get sloppy if the pressure gets too low. So it seems it would be better to be a little on the high side than the low. Of course, all this assumes you have a very accurate gauge.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #3 of 8 Old 05-04-2014, 10:07 PM
V-Tom's Avatar
I'm 240 to 250 lbs.
I run about 40 front and around 42 rear. For what it's worth I run Tourance tires.
..Tom
SMIDSY detailed report.
V-Tom is offline
post #4 of 8 Old 05-04-2014, 10:40 PM
cpd419's Avatar
I'm 200 lbs and I run about 35 front 37 rear cold.
2013 DL650
cpd419 is offline
post #5 of 8 Old 05-05-2014, 12:00 AM
BKP
BKP's Avatar
I'm running Michelins, and have always found they run best about 1-2 PSI north of swingarm recommendations.
[B][I]Barry[/I]
2017 Pearl White 650[/B]
AdventureTech lowering links and GPS mount
AdventureTech +2" SS braided brake line
Madstad windscreen
GPI spools, SW Motech risers
Givi XS307 Tanklock bag and Givi 46L top case
Suzuki hard case saddlebags
BKP is offline
post #6 of 8 Old 05-05-2014, 12:09 AM
John, you'll get answers that range all over the place. There is no consensus.
Try telephoning the customer service number for your brand...1-615-937-3442 for Bridgestone, for example. Pls let us all know what they say.
I'm 200# + gear, I run 33/36, and the center wears when I'm on a straight road. The sides wear when I can find a fun road. Others run pressures up to the tire's max, 42, or the pressure to carry the max the bike is rated to handle at each end, 41. Neither is the recommended pressure unless that much weight is actually on the tire, but they like the results.
post #7 of 8 Old 05-05-2014, 08:27 AM
ProZac's Avatar
I don't think the OP was asking what pressure he should run he was just asking what others were running.
I'm a big boy also. On the Vee I run 36-38 rear and 32-34 front no matter what kind or tires I will run them at those pressures on the Vee loaded or not. My wife's F650GS gets 32 front 34 rear.
ProZac is offline
post #8 of 8 Old 05-05-2014, 11:28 AM Thread Starter
johnnail's Avatar
Yeah, I just wondered if I'm the only one who runs above the posted pressures. It would be nice to somehow avoid so much center wear----but the goofy things are round, after all
johnnail is offline
