instrument panel blackout - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 05-03-2014, 02:58 PM Thread Starter
My instrument panel went blank today (2012 650 vstrom). The Tach doesn't work either nor do the signal lights or brake light. The headlight works. The panel does show when the high beams are on. Other than that...blank. Has anyone had a similar experience? I'm hoping its loose wiring and not something more serious.
Todderick is offline
post #2 of 8 Old 05-03-2014, 03:12 PM
fortp's Avatar
Fuses are OK?
fortp is offline
post #3 of 8 Old 05-03-2014, 05:13 PM
everready's Avatar
Check to see if connections are secure and check under the seat for tight
battery connections. Also make sure you don't have stuff, (tools and whatnot) loose under the seat.
2013 DL650A "Blue"
Previous bikes: '78 CB750F, '86 Nighthawk S, '87 EX500, '85 Sabre 700, '93 Katana 600, '75 Rupp 80, '78 DT250, '88 TT225, '89 CR250
everready is offline
post #4 of 8 Old 05-03-2014, 05:20 PM
Aka
Aka's Avatar
Given I just took off the front of my bike today, it's fresh in my mind.
When checking for connections under the seat and fuses, also check the three connectors in a black rubber/plastic slip cover beside the left fork/behind the left headlight. Check that those are connected properly. Not sure which does what, but those power everything in the dash, headlights, signals, etc...
Aka is offline
post #5 of 8 Old 05-03-2014, 06:46 PM Thread Starter
Thanks everyone. Im not mechanically inclined and had no idea. Turns out it was fuse 15A (signal). I replaced it with the spare and everything seems to work. Not sure what caused it. I have aftermarket handwarmers but didnt use them today; it was 14C In N.B. Now to buy a replacement spare...
post #6 of 8 Old 06-10-2015, 11:11 AM
Dave MP's Avatar
Thread revival!
Having the same issue today.
Not sure what is causing it, but the 15A (signal) fuse is blowing immediately after turning key to the ON position.
Looking for other ideas as to cause.
The only other item attached to the turn/brake lights is an AdMore SMT Light Bar (installed last year).
Dave MP is offline
post #7 of 8 Old 06-10-2015, 02:16 PM
Uncle Fester's Avatar
It's grounding out somewhere. hopefully it is not the main wiring harness. There have been some issues.
Uncle Fester is offline
post #8 of 8 Old 06-10-2015, 02:57 PM
Dave MP's Avatar
Success!
Found the issue (12 15a fuses later).
There was a wire for the license plate light that had frayed enough to short out.
Coated it with liquid tape, then wrapped more tape on top. Everything seems to be working good now.
If it happens again, will cut the wires then add shrink tubing.
Dave MP is offline
