Sprocket change - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 04-26-2014, 12:54 PM Thread Starter
2ManyCrashes's Avatar
Sprocket change
I just put a 16T front sprocket on my '13 650. I felt 1st and 2nd were geared too low, and the other gears could using spacing out as well. I had also compared the speedometer to my Garmin GPS and it was 7 or 8% high. The taller gearing has put the speedo right on the money and the engine has no problem pulling the taller gearing. Try it, you might like it. A front sprocket can be had pretty cheaply, usually under $20.
2ManyCrashes is offline
post #2 of 11 Old 04-26-2014, 01:10 PM
Keith Falkner's Avatar
I agree with you that the front sprocket should have more than 15 teeth. I have tried 16 teeth, but I find 17 teeth to be proper for me. I think this is a matter of personal preference, and I like seeing the tachometer near 5000 while I am making my long rides.
I am not sure about the change in sprocket affecting the accuracy of the speedometer. Someone will probably pipe up and tell us whether your findings are accurate.
When a little change helps you enjoy your ride significantly more,
than it is a beneficial change, and not very small after all, eh?
(The "eh?" just slipped out. I am headed for Canada next week, eh.)
Keith
P.S. funny thing. You give your location as N W Indiana. Well, that would be near the Indiana-Michigan state line,
which is the very first state line that my Florida-based Wee-Strom rolled over. (Yawn, if you like; there is more.)
And the first ocean that I saw from its seat: Pacific. And the first place where it reached the Atlantic Ocean?
Belfast Maine.
Keith Falkner is offline
post #3 of 11 Old 04-26-2014, 01:43 PM
I'm sure about the 16T front sprocket, speedo almost exactly mirrors a GPS speed info.
Oop North John is offline
post #4 of 11 Old 04-26-2014, 02:41 PM
TinMan2's Avatar
I find the first gear a tad too tall on my 2012 Adventure when doing slow dirt or gravel trails. It's not a dirt bike but I do like the choice of seeing where the dirt road or smooth trail goes at a speed I can look around. Couldn't do that with any higher gearing. If I was using it for strictly highway riding then I would probably do the bigger front sprocket.
TinMan2 is offline
post #5 of 11 Old 04-26-2014, 02:57 PM
DRD
17!! I've had a 16t since it was new and love it. I have to slip the clutch a bit more in first but I can't imagine being at a traffic light on an incline. But I guess if you area supports a 17 then cool.
DRD
2013 Blue DL650
DRD is offline
post #6 of 11 Old 04-26-2014, 07:29 PM
Been there done that. I missed the torque, so I went back to the 15. To each his own, I suppose.
Kevin
L2 DL650A The Orange Machine
K7 DL650 Hi Yo Silver R.I.P!
khager is offline
post #7 of 11 Old 04-26-2014, 08:44 PM
chicago's Avatar
We have had this conversation before.
Installed a 14 tooth recently. Great for winding back roads, slow speed on the rougher roads and also for maneuvering in parking lots. I find it's great on the highway too. Top end of 100 + has been confirmed. Does everything it did before, it's just more fun now.
chicago is offline
post #8 of 11 Old 05-22-2014, 11:06 PM
Motor7's Avatar
I just pulled this thread up on a search. I'm going to try a 14T front since I will be doing a lot of off road/gravel. I seldom go over 80mph, so this swap should not present a problem.
Motor7 is offline
post #9 of 11 Old 05-23-2014, 08:32 AM
sbeadg's Avatar
I tried it.....personally, I didn't like it.
For the 2 lane riding I like to do, I like having the gear ratios as they came from the factory. I can loaf along in 5th or stay in 4th when there's more fun to be had on the road ahead. Our bikes shift so smoothly, its not something I mind doing.
I think many think the engine is working too hard above 5k rpms and on many bikes, it is. It sounds very happy and eager to me...
'15 Tiger800 XRx
'99 Triumph Thunderbird Sport
'89 Honda NX250
"Why don't I have tattoos? For the same reason you don't put a bumper sticker on a Ferrari."
sbeadg is offline
post #10 of 11 Old 05-23-2014, 08:38 AM
D.T.'s Avatar
I tried the 16T also and liked it. BUT..
the 15T is better for all around riding like dual sport type for me so I went back to stock. If I used the bike for slabbing and had sport touring tires on it 16T would be the norm, that's my preference. 14T? Maybe if it went full MX mode. :mrgreen:
D.T. is offline
