wheels - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 04-18-2014, 09:46 PM Thread Starter
wheels
Will the front wheel from an 04 DL6550 fit my 12 DL 650? Just started getting the front end shake and thought I would see if it is the tire by putting my wife's front wheel on it.
deputygene is offline
post #2 of 7 Old 04-18-2014, 09:58 PM
I doubt it but it may be possible. The ABS won't work and there may be a problem with the brake rotor position or axle spacers. You can try it and let us know.
post #3 of 7 Old 04-19-2014, 12:14 PM
srevac's Avatar
Front end shake
What type of front end shake are you getting? I have a noticeable shake from 30 mph to 45 mph. I took it to the dealer, he took the wheel off and he said everything seemed ok, but I still have it.
srevac is offline
post #4 of 7 Old 04-19-2014, 06:34 PM
oink's Avatar
Perhaps the steering nut needs a little tightening?
oink is offline
post #5 of 7 Old 04-19-2014, 06:42 PM
I think the shake is quite common, and I think it's a combination of factors, slightly loose steering head bearings and slight cupping of the front tire from underinflation, and flexy front forks. I run about 36 psi front and that helped some, also snugged up the steering head bearings, but what really helped was the addition of a fork brace, even with the cupped front tire(to be replaced SOON), the shake is damn near gone.
bikerfish is offline
post #6 of 7 Old 04-19-2014, 08:11 PM
srevac's Avatar
Front wheel shake
Thanks for the comments. Interesting, however mine was checked at about 700 miles, so no tire cupping, inflation of tire was checked and I have Adventuretech's fork brace installed with no evident improvement in shake. I'll have the steering head tightness checked. Thanks again for the input.
srevac is offline
post #7 of 7 Old 04-19-2014, 09:06 PM
raYzerman's Avatar
Try putting 42 psi in the front tire and ride it for a bit to see if it improved, then you'll know if the tire is contributing.......
raYzerman is offline
