Visibility - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 04-16-2014, 08:09 AM Thread Starter
Visibility
Does anyone have any information on where to buy the reflective diagonal stripe tape that is on the back of fire trucks, buses, etc. I have looked around here at safety supply stores and on the internet, but seem to come up empty. Thanks in advance.
sdhamlin48 is offline
post #2 of 13 Old 04-16-2014, 08:14 AM
I've gone with streetglo.net for my reflective decal and tape needs
robardin is offline
post #3 of 13 Old 04-16-2014, 08:17 AM Thread Starter
Thanks
Thanks Robardin, I will check it out.
post #4 of 13 Old 04-16-2014, 08:25 AM
One place I like to recommend is Conspicuity, Inc. Reflective Products since the company was started by people I used to teach motorcycle safety alongside. Their stuff is primarily for motorcyclists and won't suffer in the usually encountered conditions like some others might.
post #5 of 13 Old 04-16-2014, 10:14 AM
568v8's Avatar
reflective tape products
Go to a local graphics company that does truck lettering. 3M make a variety of reflective products; one that I use appears to be almost the same black colour as my Vee in daylight but reflects well at night.
But the red/white reflective stripes seen on trucks can't be beat.
Road Toads Charter Member - old guy goes stromabout on a 2007 Vee and finally has touched all of the 48 contiguous United states and the 10 Canadian provinces.
568v8 is offline
post #6 of 13 Old 04-16-2014, 10:33 AM
Natche is offline
post #7 of 13 Old 04-16-2014, 11:42 AM
StarChamp's Avatar
You can also get it from your local Lowes, maybe Home Depot as well, in the section where the keep trailering and towing supplies.
StarChamp is offline
post #8 of 13 Old 04-16-2014, 12:16 PM
The red & white retroreflective tape you see on truck trailers is grade DOT C2. It gives the brightest reflection over the widest viewing angle. The engineering grade material on fire trucks is less bright, but stands out due to the large surface area of the side of the truck. The DOT C2 tape is available in lots of auto supply stores and the auto supply of many other stores.
SOLAS tape (Safety of Life at Sea) is brighter but over a narrow viewing angle. It is designed to reflect brightly back to a single point such as a searcher behind a spot light on a helicopter or search boat.
post #9 of 13 Old 04-16-2014, 12:38 PM
Banned
Menard's discount hardware store.
http://www.fuelly.com/driver/jbw/dl1000
JRWalker is offline
post #10 of 13 Old 04-16-2014, 10:53 PM
chicago's Avatar
Years ago a local rider was killed when he was rear ended at speed on the highway by an impaired driver. It was a hit and run. Fortunately the car sustained damage to the cooling system and didn't get far, was found and driver apprehended.
I found this stuff on Amazon. I like that solas stuff also.
chicago is offline
