Torque specs for front axle - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Downs
post #1 of 7 Old 04-09-2014, 12:35 AM Thread Starter
Does anybody have the torque values for the front axle and brake calipers? Is anti seize a good idea on the axle threads, or clean and dry?
deuce is offline
post #2 of 7 Old 04-09-2014, 01:27 AM
Downs's Avatar
FSM Calls for
Front Axle/47 Ft Lbs
Front Axle Pinch Bolt/16.5 Ft Lbs
Brake Caliper Mounting Bolts/28 Ft Lbs
OliverWinn likes this.
Downs is offline
post #3 of 7 Old 04-09-2014, 01:32 AM
There is no stainless on stainless so clean and dry is fine. Anti seize would be okay on the axle if the torque was reduced to about 80% of spec. and the pinch bolt would keep the axle from loosening anyway. If anything, I would put blue Loctite on the caliper bolts.
post #4 of 7 Old 04-09-2014, 11:36 AM Thread Starter
Many thanks, friends.
deuce is offline
post #5 of 7 Old 08-24-2019, 12:28 PM
fig
fig's Avatar
In case anyone stumbles upon this thread, I don’t think that axle spec. is right. Better double check.
fig is offline
post #6 of 7 Old 08-24-2019, 02:29 PM
Haynes says 65 NM which is 47.97 foot pounds.
Ron
Belton Tx
2013 650
MPRblue is offline
post #7 of 7 Old 08-24-2019, 06:03 PM
fig
fig's Avatar
I guess the 650 is different then the 1000.
fig is offline
