Accessory lights on Crashbars Drill or not Drill? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 03-24-2014, 08:56 AM Thread Starter
Captain Farkle's Avatar
Hey guys,
I got a set of those Cree lights and purchased mounts for my SW Motech Crash Bars for them. Where do you suggest I can hide the wires. They will travel to the back of the bike where the PC8 is situated. I have read some people drill a hole in the crash bars and use a gromet. Not sure if this is a good option as the bars could weaken. Has anyone done a similar setup? I was thinking to use tape along the back of the bars, does anyone have a good suggestion on strong water resistant tape? Or is that a bad idea also.
2012 650 Vstrom Black - Givi E52 Maxia Trunk,Givi Quick Release PLR3101 Racks, Givi E21 Silver Side Cases, Admore LED Brake and turn signals, SW Motech Crash Guards, SW Motech Center Stand, SW Motech Steel Rear Rack, SW Motech Bar Risers, OEM lower Cowling, OEM lower Seat customized by Triple K Upolstery, OEM Hand Guards, Eastern Beaver PC8, Givi Airflow Windscreen, Aprilla Mirrors, Dan Vesel Highway Pegs and Back Rest, Oxford Sport Heated Grips, FendaExtenda, Sena 10C, CREE LED Headlight Kit,10w Cree LED Work Lights,INNOV Wifi Bullet Cam
Captain Farkle is offline
post #2 of 3 Old 03-24-2014, 09:35 AM
bosnjo's Avatar
Don't drill crash bars. I'm waiting for mines to arrive and I'll install them on crashbars using mirror clamps for handlebars. I'm not sure they are the same size, but I'll use some rubber or beer can foil to bring the bars to right size. Just to see what I was talking about, search for the item number
261252262470
on eBay and look at the picture. That will give you some new ideas. There are those clamps in black and silver and probably some other colours.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #3 of 3 Old 03-24-2014, 09:48 AM
261252262470
Agree, no drilling to hide wires, use heat shrink tubing and zip ties, I used these: 400508741066 from fleabay. I then used the soft part of velcro tape that I used as a anti-scratch and wrapped around the bar under the clamp. The clamps were a perfect fit. as my bars are 20mm not 22mm.
dogdaze is offline
