Pictures of Modified a Seat Bumpers on Underside - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 03-23-2014, 10:51 PM Thread Starter
Hello all,
I am looking for pictures of mods to the seat on 2013 650. Please post what you have.
Also, What's a clean method for cutting pads?
Thanks!
Stalzie is offline
post #2 of 11 Old 03-25-2014, 11:10 PM Thread Starter
Bump. Cleanest cutting method? Cut all of them? just some? Thanks
Stalzie is offline
post #3 of 11 Old 03-25-2014, 11:14 PM
kiwi_outdoors's Avatar
don't cut them
they isolate vibrations
I bought my bike used, without the rubber isolators under the seat
and I replaced them all - much better
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #4 of 11 Old 03-26-2014, 12:48 AM
What is your goal?
k6wee is offline
post #5 of 11 Old 03-27-2014, 09:52 PM Thread Starter
I would like to lower the bike a hair without using lowering links. If I removed them would furniture pads work? I just don't want to remove or cut them and have slop. Has anyone else done this? Thank you for your replies.
Stalzie is offline
post #6 of 11 Old 03-27-2014, 10:12 PM
njbill's Avatar
I am confident I read (here) that people were removing them to lower the seat. However, I cannot find that thread.
njbill is offline
post #7 of 11 Old 03-28-2014, 01:54 AM
J3D
Removing the pads is mentioned in this video from galevelasco https://www.stromtrooper.com/820127-post2.html
And freyguy17 mentions chopping his down some here: https://www.stromtrooper.com/857664-post1.html
J3D is offline
post #8 of 11 Old 03-28-2014, 09:26 PM Thread Starter
Thanks for the links and video! I'm going to try removing the bumpers.
Stalzie is offline
post #9 of 11 Old 03-29-2014, 08:08 AM
I would'nt bother cutting them , it will gain you bugger all , just remove them , spray a bit of wd40 on them before you either pull them or replace them , takes 2 minuits .
I removed mine theres been no damage to the paint , the seat seems a bit sloppy if you push and pull it , but once sat on it , it does'nt move . If that does'nt work try the lowering links , it does'nt alter the handling of the bike , at least not that you would notice .
coneye is offline
post #10 of 11 Old 04-06-2014, 08:34 AM
Try removing them and taking some fuel hose or heater hose and splitting it so it will fit over the frame rails and faster with zip ties.
loosesprocket is offline
Tags
adjustment , height , lowering , mod , seat
