How much pre-load? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 03-23-2014, 09:16 PM Thread Starter
How much pre-load?
Hi all - my wife weighs 112. How many turns on the suspension adjuster do you recommend, for her to ride as a passenger? Right now it's at the factory setting - in the middle. Thanks for your help.
Jim C
jimc068 is offline
post #2 of 7 Old 03-23-2014, 09:26 PM
RichDesmond's Avatar
Jim C
With any passenger, max out the rear preload.
Rich Desmond
RichDesmond is offline
post #3 of 7 Old 03-24-2014, 03:25 AM
Don_T's Avatar
How to set suspension sag - Motorbike Suspension Reviews | MCN
Yamaha XT1200Z '15 - www.bike-addict.dk - It's not what you ride but how you ride it unk:
Don_T is offline
post #4 of 7 Old 03-24-2014, 08:13 AM
This reminds me that I have been meaning to ask about carrying a passenger.
I want to take my hadicap brother for a ride on my bike, but he is pretty big. I am 6 foot 3, around 210lbs with gear. He is about the same size, maybe a little lighter (like 200lbs with gear)
I THINK based on the GVWR for the bike, that it can handle 500lbs worth of passenger but I don't know if that includes fuel or not.
Would it be ok for me to take my brother for a ride based on my and his weight?
bandroidx is offline
post #5 of 7 Old 03-24-2014, 09:56 AM
It's interesting the article uses the example of 40mm being too much sag. Sport bikes have less travel than V-Stroms. 40mm is an excellent number for our bikes.
post #6 of 7 Old 03-24-2014, 10:15 AM
It will be fine.
Rich Desmond
post #7 of 7 Old 03-24-2014, 12:21 PM
To summarize---
Everyone should set the sag, front & rear, to get the bike properly set up for themselves. There is no correct "factory" setting; one rider might be 120# and the next rider 320#. Both front & rear on the strom do good with sag close to 40 mm. Sag is set with preload adjusters. The purpose of the sag setting is to get the suspension in about the middle of its travel to minimize the chance of either topping out or bottoming out.
You can do the front yourself. Get a helper for the rear.
When carrying a pax set the tire inflation pressure higher for the rear--I follow the sticker on the swingarm (same as the owner's manual).
