Chain Lube ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 31 Old 03-23-2014, 05:09 PM Thread Starter
Location: North Augusta, South Carolina,USA.( C.S.R.A. )
Question Chain Lube ?
I have a 2006 dl 1000 and a 2012 dl 650 adventure what is the best chain lube that will not fly off and get the rear rims messy and get all over my two brothers cans? I have used the spray on white lithium grease and the white graphite grease chain lubes.What is the best chain lube for me.
RICK
PSALM 31
REMEMBER YOUR SAFETY FIRST ALWAYS WEAR YOUR HELMET
My Current Motorcycles
2010 Honda VFR1200F Manual ABS Sport Touring
2008 Kawasaki VN2000J Vulcan 2000 Classic LT Big 2053 cc Cruiser
OUT DOOR SOUTH is offline
post #2 of 31 Old 03-23-2014, 05:32 PM
Try PJ1, Stays on the chain. Just wipe the extra.
LeeK is offline
post #3 of 31 Old 03-23-2014, 05:36 PM
Motorcycle Chain Lube Reviews - webBikeWorld
post #4 of 31 Old 03-23-2014, 05:56 PM
Is liquid wrench a good chain lube?
2012 Suzuki VStrom DL1000
2009 Kawasaki ER6N
2008 Harley Ultra Classic
2006&2007 Lifan 200
2003 Honda VTX1800
1975 Honda CB200
1974 Yamaha RD200
1973 Yamaha TX650
terryJ is offline
post #5 of 31 Old 03-23-2014, 06:26 PM
From More Motorcycle Chain Lubes Reviewed - webBikeWorld
Our Opinion
Liquid Wrench Chain Lube was suggested by webBikeWorld readers. It is one of the few readily-available, retail sprays that actually does state that it's O-ring safe. However, it sprays on as an oily liquid and doesn't dry, so it leaves the chain "wet", prone to collecting dust and dirt.
Conclusion
We think the Liquid Wrench Chain Lube spray is better suited for use as a general shop lubricant rather than for a motorcycle chain.
Read the Web Bike World review link already posted.
post #6 of 31 Old 03-23-2014, 06:51 PM
chicago's Avatar
I like and use Liquid Performance. No mess. I get it online.
chicago is offline
post #7 of 31 Old 03-23-2014, 07:29 PM
BKP
BKP's Avatar
I like both PJ1 Blue, and Bel-Ray Super Clean Chain Lube. Prefer the Bel-Ray, though. Sprays on much waxier than others I've used -- hardly any drip at all. Gives the chain a somewhat whitish, almost paraffin look, but this stuff stays put! Says O, X, Z ring safe right on the can.
Oh... and the typical road crap doesn't seem to stick to it at all...
[B][I]Barry[/I]
2017 Pearl White 650[/B]
AdventureTech lowering links and GPS mount
AdventureTech +2" SS braided brake line
Madstad windscreen
GPI spools, SW Motech risers
Givi XS307 Tanklock bag and Givi 46L top case
Suzuki hard case saddlebags
BKP is offline
post #8 of 31 Old 03-23-2014, 07:33 PM
Banned
Candidates
Personally,
I can't rule out all of the following choices as economical alternatives, but I also believe you need to used Kerosene from time to time prior to applying these:
RE: Liquid Wrench Dry Lube
Webbikeworld review:
Good stuff actually, with some potential. It seems to work just like the old version of DuPont Dry Wax lube. We have contacted the manufacturer to see if the product is O-ring safe and we're giving this a longer-term evaluation as a motorcycle chain lube.
From "B.W." (September 2012): "Based on your review, I went to Liquid Wrenchs website to get more info on the Liquid Wrench Dry Lube. (My stock of the original DuPont Dry Wax lube is running low!) It linked to the attached 2008 data sheet (.pdf) for Solder Seal/Gunk Dry Lube with Cerflon aerosol, which Im assuming is the original name for the product.
The data sheet is helpful for two reasons: 1) the formula contains Teflon and sure sounds like the DuPont lube; and 2) it specifically states its safe for rubber which should mean its o-ring safe. Looking forward to your long-term test report!"
DuPont(R) Teflon(TM) Chain-Saver Lubricant, Net Wt 11 oz.
DuPont Silicone Bike Lubricant Aerosol
DuPont Motorcycle Chain Lubes
XLonDL650 is offline
post #9 of 31 Old 03-23-2014, 07:34 PM
davesride's Avatar
Ditto here, love the stuff. Belray Superclean, goes on easy and stays clean!
I know, sounds like a corney 50's commercial....lol
Some can't...some won't.... I might!
Richland Ricks Fork Brace and Mirror extenders, Stebel Nautilus Horn, Suzuki Centerstand
davesride is offline
post #10 of 31 Old 03-23-2014, 07:39 PM
VSrider's Avatar
Dupont Teflon Chain Saver. It does fly off a little but it's good stuff.
VSrider is offline
