Front fender and mud issue?!? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 15 Old 03-18-2014, 08:46 PM Thread Starter
Well I went and played in the mud today with the vstrom... Something happened that was a huge nuisance ... It became locked.... Mud wedged between the fender and the tire... It was so packed that I had to remove the fender and clean it out during the ride twice... Super annoying ... My buddy had his f700gs and it had about another inch of space and he had no issues.... Is there a product out there that can help me? I just need another inch of clearance...
Jessesmith121 is offline
post #2 of 15 Old 03-18-2014, 08:52 PM
fortp's Avatar
You were lucky being able to remove the fender during the ride, with that square nut behind, that turn in the plastic.
I had to drill my bolts head.
fortp is offline
post #3 of 15 Old 03-18-2014, 09:01 PM
T-ville Trooper's Avatar
I had the same problem last fall. there was four of us on the ride and all had the same problem.
There was one reply that said that he raised the front fender 2".
There is another problem with the rear tire putting mud and rocks in the chain.
On my bike it filled the front sprocket cover with mud and rocks. I ended up pulling it off and cleaning it out.
T-ville
T-ville Trooper is offline
post #4 of 15 Old 03-18-2014, 09:10 PM
worse outcome
If the mud dries under the front fender, then you get a stick caught in there at speed, well you end up down the road when it all locks up. Nasty.
I would be likely to raise the mudguard 2 inches if someone did a kit for this purpose.
xrman is offline
post #5 of 15 Old 03-18-2014, 09:36 PM
Bikehigh's Avatar
Funny that this topic came up today. I just pulled the front fender off today to install a fenda extenda, and to raise the fender a bit when I reinstall it. I've got a superbrace on the fork, and it looks like the very most I'll be able to raise the fender is 1". More likely a bit less. I got some plates, and some nuts and bolts, and I'll see what I end up with. I'll do what I can to document it.
Bikehigh is offline
post #6 of 15 Old 03-18-2014, 10:14 PM
DRD
Touratech sells an off road fender for just that problem..
Off-Road Front Fender, Suzuki V-Strom DL650, 2012-on - Touratech-USA
DRD
2013 Blue DL650
DRD is offline
post #7 of 15 Old 03-18-2014, 11:03 PM Thread Starter
Not wanting to spend 200 plus shipping on a solution... When only an inch or so is needed...
post #8 of 15 Old 03-19-2014, 10:10 AM
Capt_phun's Avatar
Can't you fab some steel extenders to tap & raise the fender up? Seems easy enough if you have a drill & a tap set and some 1/4" steel flat bar.
DL650 Adventure Trax Box Carrying Handles/Lashing straps. --> click link to view info & how to order: [url]https://www.stromtrooper.com/dl650-2012/80136-trax-box-carry-handles-lashing-straps.html[/url]
Capt_phun is offline
post #9 of 15 Old 03-19-2014, 12:13 PM
D.T.'s Avatar
$200 for a fender?? :shocked:
I just don't ride in heavy mud.
D.T. is offline
post #10 of 15 Old 03-19-2014, 05:43 PM
Bikehigh's Avatar
I made up a set of brackets to raise the fender an inch and did a trial fit on the fender. Found that in order to mount it I'd have to butcher the fender. There's no going back from that, and I'm not willing.
In order to have the new mounting points clear the plastic of the fender, I'd have to raise it by at least two inches. That presents a few other issues. I'd have to lose the fork brace, the crossover brake line won't accommodate that, and I gotta wonder if the fender may then contact the radiator or cowling with suspension fully compressed. If the last isn't an issue, and I don't know that, then two or more inches is certainly doable with no brace and no crossover.
Bikehigh is offline
