fuse in battery tender lead - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 22 Old 03-13-2014, 02:29 PM Thread Starter
Any problem replacing the 7.5 amp fuse with a 15 amp one? Wired to my battery and goes to a 12 volt outlet want to run a cycle pump. Also charge cell phone. Thanks.
Maddog251f is offline
post #2 of 22 Old 03-13-2014, 02:41 PM
They probably didn't put a 7.5 amp fuse in just because they had some spare.
You'll probably get away with it, but it will be "interesting" if the cables power limit is reached before the fuse blows, as what can you do then, apart from getting the seat off quickly and disconnecting the battery. A pair of snips to cut the wire might be helpful.
May you live in interesting times, is I believe, a Chinese curse.
Oop North John is offline
post #3 of 22 Old 03-13-2014, 03:26 PM
As long as the wire is 16ga or thicker, it won't be a problem. With a short run, 18ga is probably even okay.
post #4 of 22 Old 03-13-2014, 04:59 PM
I would not just cut the wires, you will ruin those snips, 12 volts prob won't arc flash enough to blind/burn you. It could be just enough volt-amps to weld/melt the snips to the wire, shorting the battery or worse kill some delicate electronic (computer). And yes I've ruined wire cutters in the past .
But like GW said, you should be ok. BTW what is a cycle pump? Is it a bicycle tire pump? The phone will only draw ~5 watts. I know just enough about electricity to respect it's power.
danhikeski is offline
post #5 of 22 Old 03-13-2014, 05:20 PM
A basic is never to cut wire pairs that are attached to a battery. Cutting them one at a time or disconnecting them before cutting is easy enough.
post #6 of 22 Old 03-14-2014, 05:34 AM
No need to cut wires, cutting only one will break the circuit, just as a fuse does.
post #7 of 22 Old 03-14-2014, 08:05 AM
MeefZah's Avatar
There seems to be a lot of misunderstanding about basic electrical stuff on this board, based on this and other threads.
I have replaced the fuse in all my battery tender leads with a 15a to power a heated vest or air compressor. The wiring is adequate, I assure you.
MeefZah is online now
post #8 of 22 Old 03-15-2014, 02:02 AM
Ahh but see your post doesn't do anything to help clear up some of those misunderstandings. It would be more helpful to say why a 15a fuse is ok.
And to make sure people understand that over amping a fuse is ok in some circumstances but not in every circumstance...
Squish is offline
post #9 of 22 Old 03-15-2014, 06:33 PM
MeefZah's Avatar
I was typing on my phone, which is always aggravating, so it was best for me to be brief.
A fuse serves two purposes, the first being protection of the wiring and the equipment from a short to ground, the second being protection of the wiring from "excess amperage" / overload / whatever you want to call it, drawn by equipment; which is what the OP and the first couple posters are concerned with.
In this situation, you are dealing with stout wiring (battery tenders are 16ga, I believe), a very short run of wiring (12" or so), and a specific, known draw on the battery - that being a 12VDC air compressor that probably draws 8 amps or less while running and maybe 10-11 amps on startup (guesses). There is no risk to the wiring melting under these conditions.
If you have concerns about an item "drawing too much power" for the wiring, then I would universally suggest not using it. However, most 12VDC accessories, especially that you might fit to a bike, aren't in any way at risk for that sort of thing. You wouldn't be running an AC invertor with a TV and refrigerator.
I always kind of laugh about fear of 12VDC electricity, it's a docile animal. If you ever wonder "is this wiring adequate", take a look at the factory wiring on your car or bike going to your headlights, which are high amp draws. That wiring will invariably be smaller gauge that that of a battery tender or any other accessory, and it holds up for years, under adverse conditions, and everyday use. Or look at the wiring on the air compressor itself, on mine it is 18 ga wiring, so clearly the unit was designed for even smaller gauge wiring than that and the 18 ga is a "overbuilt" as a failsafe... so the larger 16 ga battery tender lead is actually substantially more than needed.
As per my original post, I have replaced every battery tender lead I have with a 15A fuse, and have run air compressors for years off them and never had an issue. In fact, I only this year got an honest to god pancake style compressor, in years past I used my little bike powered 12VDC model to inflate car tires and the like. None of the wiring is melted, no excess heat noted during use, no blown fuses, etc. The tender wiring continues to also work fine to power my heated vest, and occasional cell phone charge while on a trip, and the actual battery charger. Even if you don't believe my anecdotal evidence, above; believe my actual experiences.
post #10 of 22 Old 03-15-2014, 09:50 PM
650wee's Avatar
I have a 5A in mine and I run a heated vest , battery tender, mini compressor for flat tires. It had a 3A stock but it blew when I plugged in the pump, so swapped it out for a 5A.
If you come to a fork in the road take it. Yogi Berra
650wee is offline
