Side stand 'play' after weight applied - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 03-11-2014, 07:18 AM Thread Starter
ok I did do some searching on this and found various info but none specific to my quest.
I have a slight concern about the amount of 'play' in side stand from when it is fully extended to when it has full bike weight upon it, which sees it extend outwards a considerable bit.
My concern is that there may be undue wear placed upon components here and in absence of centre stand a failure is a major problem on a trip.
My searching found people trying to reduce travel, insert washers etc....
I'm not actually bothered about the travel after weight added, but more so ..
IS IT NORMAL ??
If it is normal then fine, but should we be watching it/monitoring it/replacing bolt when travel reaches 'x' assuming its possibly worn the bolt through?
Any info be appreciated,
Might be worth noting, I have the official Suzuki workshop manual and cant find reference to it in there? (it may be there, I just cant find it referred to?)
Thanks
2012 DL650
Honda CBR1000RR
Nugget173 is offline
post #2 of 12 Old 03-11-2014, 07:29 AM
Majster81's Avatar
Mine has a little play from where it's fully extended to when the bike is fully rested. I don't worry about it too much as long as I don't rest it on soft grass or very un-even surface.
Majster81 is offline
post #3 of 12 Old 03-11-2014, 02:42 PM
UncleRandy's Avatar
Movement/Play in the side stand is perfectly normal. I disassembled mine just to checkout this very issue. The hole in which the kickstand bolt and bushing are inserted is elongated to allow for this movement. Mine moves about 3/8 of an inch. Nothing to worry about.
UncleRandy is offline
post #4 of 12 Old 03-11-2014, 03:07 PM
dravnx's Avatar
I went through this same excercise. I even went down to the dealership to check out a new bike. The play is normal.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
dravnx is offline
post #5 of 12 Old 03-11-2014, 03:15 PM
BKP
BKP's Avatar
The play existed on my original side stand, as well as on my Soupy's adjustable side stand. Have to believe this was designed in.
[B][I]Barry[/I]
2017 Pearl White 650[/B]
AdventureTech lowering links and GPS mount
AdventureTech +2" SS braided brake line
Madstad windscreen
GPI spools, SW Motech risers
Givi XS307 Tanklock bag and Givi 46L top case
Suzuki hard case saddlebags
BKP is offline
post #6 of 12 Old 03-11-2014, 03:55 PM
Just as a side note, but I've been riding for @ 35 years and I can remember when side stands used to have a 'lock' (for want of a better word) that would keep the side stand, while in the lowered position, from moving in case the bike rolled forward and off the stand. Is my mind playing tricks on me or does anyone else recall this very simple design that no longer exists?
dogdaze is offline
post #7 of 12 Old 03-11-2014, 06:30 PM
madstrom's Avatar
IS IT NORMAL ??
Thanks
I went through all of that on my 2006. I even ordered a new side stand and bolt to "fix it" with no change. Then I ordered a new bracket with no change. Then I bought an almost new 2011 with the same results. Apparently the fact is, there's some built in slack even when brand new.
madstrom is offline
post #8 of 12 Old 03-11-2014, 06:45 PM
Banned
replacing bolt when travel reaches 'x' assuming its possibly worn the bolt through? Any info be appreciated,
i replaced the bracket & bolt for no good fix. i realize now that i should have replaced the kick stand for correct fix.
JRWalker is offline
post #9 of 12 Old 03-11-2014, 07:06 PM
chicago's Avatar
HD has a stand like that. I'm not aware of others.
chicago is offline
post #10 of 12 Old 03-12-2014, 09:48 AM
bosnjo's Avatar
Originally Posted by madstrom View Post
Then I bought an almost new 2011 with the same results...
Whole new bike just because of sidestand doubts????????????????
Just joking... Sorry, couldn't help it!
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
